rear axle code
Old 04-08-2008, 05:53 PM
kenpobuck's Avatar
kenpobuck
kenpobuck is offline
rear axle code
I just bought an 86 f250 4x4 with a 6.9 and c6 tranny. The tag is missing from the rearend and C9 is what the door sticker says the axle code is but my chiltons does not list this number. Iwould like to find out what the ratio is. Anybody out there know?
Old 04-08-2008, 06:55 PM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
Old 04-08-2008, 06:59 PM
misnomer's Avatar
misnomer
misnomer is offline
From the info I recieved, that should be a Ford LS rear end with 3.55
Old 04-08-2008, 07:01 PM
misnomer's Avatar
misnomer
misnomer is offline
axel codes,manufacters,gvw and some sizes for 80-86.
Conventional:
13 Ford 3750 4.11(8.8)
14 Ford 3750 3.00(9")
16 Ford 3750 3.50(9")
17 Ford 3750 2.47(8.8)
18 Ford 3750 3.08(8.8)
19 Ford 3750 3.55(8.8)
22 Dana 5300 4.10
23 Dana 5300 3.54
24 Dana 5300 3.73
25 Ford 5300 4.10
26 Ford 4050 3.55
27 Ford 5300 3.73
29 Ford 5300 3.55
31 Dana 6250 3.07
32 Dana 6250 4.10
33 Dana 6250 3.54
35 Ford 6250 4.10
38 Ford 6250 3.08
39 Ford 6250 3.55
72 Dana 6300 4.10
73 Dana 6300 3.54
42 Dana 7400 4.10
43 Dana 7400 3.54
45 Ford 7400 4.10
49 Ford 7400 3.55
52 Dana 7400 4.10
53 Dana 7400 3.54
62 Dana 8200 4.10
63 Dana 8200 3.54
65 Ford 8200 4.10
69 Ford 8200 3.55
Limited Slip:
H3 Ford 3750 4.11
H4 " " 3.00
H6 " " 3.50
H8 " " 3.08
H9 " " 3.55
B2 Dana 5300 4.10
B3 " " 3.54
B4 " " 3.73
B5 Ford 5300 4.10
B7 " " 3.73
B6 " " 3.55
C2 Dana 6250 4.10
C3 " " 3.54
C5 Ford " 4.10
C9 " " 3.55
G2 Dana 6300 4.10
G3 " " 3.54
D2 " 7400 4.10
D3 " " 3.54
D5 Ford " 4.10
E2 Dana " 4.10
E5 Ford 8200 4.10
F9 " 8250 3.55
Old 04-08-2008, 07:52 PM
kenpobuck's Avatar
kenpobuck
Thanks guys, this is a great site.
Old 09-21-2010, 10:33 PM
mrblonde108's Avatar
mrblonde108
mrblonde108 is offline
code 52
dana 70 i guess? Is it worth anything???
Old 03-16-2022, 07:16 PM
prepmaster's Avatar
prepmaster
prepmaster is offline
6th Gear
Hi! Sorry to dig up an old thread. I'm interested in the E2 and E5 axles but do not know what trucks to look for. I have a 98 e350 cutaway with a dana 70 but its non-limited slip. I'd like to change that.
Old 03-17-2022, 02:15 PM
Charmalu's Avatar
Charmalu
Charmalu is offline
Going to have to do some Google searching.
I found this for the E2...
https://www.garysgaragemahal.com/axle-ratios.html
https://www.google.com/search?q=ford...h=536&biw=1138
Charlie
Old 03-17-2022, 02:29 PM
prepmaster's Avatar
prepmaster
6th Gear
Charlie
Thank you, Charlie. I did some digging last night and kept running across the same info from blueoval. That garagemahal site does help fill in some blanks. Gave me some years. I actually did track down a guy in Texas with a F5 axle. I'm hoping it'll drop in my truck. My truck has an RV frame I think. 98 E350 cutaway. It's 42 1/2 in wide. The spring centers are probably at 47". I'm waiting for the guy to get back to me. I wonder, could I swap out the differential? My code is 52. I have a DANA 70 from what I'm reading.
Old 03-18-2022, 05:01 PM
Robfinger's Avatar
Robfinger
Robfinger is offline
IIRC what you got is a D70HD, basically D80-sized axle tubes with a D70 diff inside the pumpkin. That F5 axle, that's a Sterling, yes the guts of that limited-slip are VERY similar to what you'd find in some Dana axles (D60 in Econoline E250 to be exact) but that's about it, can't just take the Sterling diff and drop it into the D70 housing.
And you can't swap the entire Sterling axle in place of the Dana cause at the very least the spring perches ain't in the right places.
And the factory limited-slip diff in Sterling axles ain't all that great to begin with, it's a friction setup rig clutches that wear pretty fast in hard use.
Old 03-22-2022, 03:42 PM
prepmaster's Avatar
prepmaster
6th Gear
research
Yes indeed, I've come across some more axles since that post. I got to see a sterling up close and realize the smaller housing. I came across a guy with a drw dana70 Limited. Fingers crossed it's wide enough. It's under a 86.
Old 03-23-2022, 06:07 PM
Robfinger's Avatar
Robfinger
If that 86 has a pickup bed on it (frame about 37" wide) then the axle will most likely be wide enough for your needs but you'll need to move spring perches and shock mounts.
If the truck is a narrow-frame factory cab-chassis then the axle will unfortunately be too narrow for you in every possible way.
IMPORTANT EDIT: your factory 98 D70 has a VSS in the diff housing, the 86 D70 you're looking at won't have that so if you swap the whole unit you'll lose your speedometer, cruise, and ABS. It might be possible to swap just the diffs and transfer the tone ring from your open carrier to the limited-slip one, but I've never worked with a Dana that old so I can't tell you for sure if this will work.
Old 03-24-2022, 10:47 AM
prepmaster's Avatar
prepmaster
6th Gear
Thank you for the info. Definitely don't want to lose the ABS like AT ALL. So yeah, I'll have to take a good look at what I got in front of me when I go meet him. I wonder if the same issue is true of a body swap. I found an 05 f350 dually. The frame is cclwb so it should be about the same length. I have a flatbed so I have wiggle room with the wheel well. I imagine I'll have to do some mount relocation and even possibly do some hose fabrication to connect everything. Should I try to get the ABS module off the 05?
Old 03-24-2022, 01:18 PM
Robfinger's Avatar
Robfinger
Wait hold on, are you thinking of dropping your Econoline cab and flatbed into the '05 F350 frame? I'd imagine that ain't gonna be easy at all - frame widths, frame rail side profiles, etc - everything will be wrong.
Here's a pretty obvious question - why don't you just get yourself a TrueTrac or Detroit SoftLocker or an Eaton E-Locker that's made for your D70 axle AND gears (cause Dana axles use different offset differentials based on the gears ratio) and install that and be done with it? Seems the easiest and most painless way out.
Old 03-25-2022, 07:21 AM
prepmaster's Avatar
prepmaster
6th Gear
There is one other issue of my front end has concrete all over it and needs to be completely replaced to be aligned. Also, I feel 4x4 would be much more advantageous than only one axle locking. At least, this is what I have read and heard plus I find myself in some muddy places. Often. My current setup has to be towed out of slicks and I have to respect the weather quite a bit. I can't even pull away if I don't have the bed loaded with weight. Truck is just too long. the non slip rear end just lets me down every chance.
Quick Reply: rear axle code
