2004 F-150 Rear disc brake, passenger side, locking up
My rear passenger disc brake is staying engaged causing the rotor to overheat, hot enough to smell when you are standing back from the truck. To explain more, I can be stationary, on a hill, and the truck will not roll back when you let off the brakes. This seems to be sporadic since when I got out of my truck this morning after a 25 minute drive, the rotor did not seem much hotter than the rest of the rotors. Any thoughts?
My parking brake was sticking, and had the same symtoms, with one extra. The truck would shake like a stripper trying to get a $50.00 bill.
Jam your e-Brake as tight as you can get it without breaking it, and then pull the release and let it fly back on its own. Mine released and I haven't had a problem since.
Also check your rotor for any wear marks. If it's new, take it back to your dealer and when he plays dumb, mention this forum. It seems to jog memories sometimes.
boulderguy
54
07-25-2013 05:40 AM
classyfish
16
02-12-2006 11:52 AM
