You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Any Excursion or truck specific way to check for bad ball joints? I have been having this knock at stop and start for a few weeks, that feels like it's coming from the driver front. Jacked up the truck and try to move the front tire it doesn't move, OK not the ball joints. I figured it was the front sway bar bushing or maybe the Driveshft/Slip Yolk needing grease as mentioned on this GREAT site. Bushing looks OK, so its the grease that's needed, feeling better already.
Brought the Excursion into a new to me independant station(he did come highly recommended by a neighbor) to check the knock. I mention that I don't think it's the ball joints or the sway bar bushing but might be the Drive shaft/Slip Yolk needing to be greased. He calls and he memtions that I need upper/lower ball joints on the passenger side, that they are about to fall off and he will show me how to test for bad ball joints, my way wasn't correct.
Truck does have close to 80000 miles so it might be due but how does one tell on this truck?
I did go to the shop and yep, the passenger side ball joints are bad, he used he same test(just jack up the tire and try to rock the tire up/down ). Just found it strange that I felt the knock on the drivers side and never even thought of checking the passenger side.
Tony, you didn't mention if you X was 2 or 4 WD but my 02 2wd needed then at 90K, I would think that a 4wd might need them sooner...I'd think that you probably do to.
It is a 2003 4x4 V10 Limited. I hope to have it back sometime today and boy these things are pricey!
Getting it ready for the camping/dog show season and making sure that everything is in tip-top shape.
New shocks/front steering stablizer/tires/SilverStars within the last 5000 miles, had a transmission flush just done. Installed a Hellwig rear sway bar, and RAS this past weekend and now ball joints. Hope that's it for a long while.
Parts and labor came to alittle over $900.00 for both sides upper/lower and the Moog greaseables were used. The labor charge was pretty steep, but the truck really rides great (could be the Hellwig and RAS which was done over the weekend), no clunk and I feel real good going into towing season.
Tony
check the u joints as well.... I just did ball joints, U joints and front steering stablizer. I also show dogs and my fear is being on the road loaded with the pups and something happening..... Leaving for Ga tomorrow, hope the truck is tight!!!
Beth
__________________ Beth
2000 7.3 with lots of stuff!!
