rear tank problem
rear tank problem
Hoping someone can point me in the right direction. My 1997 powerstroke has dual fule tanks. I run the truck 90% of the time on the front tank which is working flawlessly. Yesterday I flipped over to the rear tank and within 1 minute the truck was running out of gas. Had to flip back to the front tank. I dont know much about the dual setup on the Fords. Anybody have any ideas of the problem. I had notice a few months ago when I switched to the rear tank that the fuel gauge would go crazy back and forth and erratic. I didn't give it too hard a look because as I said I use the front tank the majority of the time. One last thing, is it possible to overfill the tank to cause a problem like this? (Venting etc). The reason I ask is I filled the rear tank until it was coming out of the neck and then this problem started. Thanks for your help. Maxx
Geez Sundy I think you have over reacted? My reply was simply implying I did not know the answer to you inquire. I dont have possesion of the truck right now to try what you asked. Appeciate ANY help. And I was only speculating on the pickup tube or valve problem. Is the valve an expensive part and /or hard to diagnose 100%. Thnks again. Maxx
on
Rear tank comes out by removing the spare tire if its one there. then the tank is help up with a two piece skid plate that is bolted to two crossmembers. Once you begin to drop the tank you unhook the fuel lines. Course the filler tube has to come off first.
i think you may have shot yourself in the foot with just using the front tank. have you looked in your fuel filter to see if you have that wonderful black, green algae?
also, i had a problem way back when i did my bronco tank mod (it was my excuse to go ahead and do it while i had the stock tank out). i noticed when my rear tank got about 1/4 empty she would run out of gas. well i dropped the tank thinking something was wrong with the float and it actually turned out to be the pickup float that sits on the bottom of the tank. i cut the end off with a brake line tube cutter, purchased a piece of SS 3/8" (i think) fuel line and bent it so it literally touched the bottom of the tank. i can now literally suck the bottom dry and no foot to lose.
-cutts-
Heres exactly what it does. Now when you switch to the rear tank the needle pegs way past full and stays there. It will not move from that postion when on the rear tank. While on the rear tank after about 30 seconds the fuel filter light pops on and then almost immediately the truck starts starving for fuel. You can immediately flip back to the front tank and things start clearing up. It runs fiine. I crawled under the truck while not running and listened to the fuel selector valve and it makes the exact noice that my 96 F250 makes. So the valve motor is working, whether there ie something wrong with the valve I dont know. Im guessing there is something in the rear tank pickup that has gotton clog. Not familiar with this sysytem is there a fuel filter inside the tank also? I have replaced the fuel filter at the motor. Thanks.
