Gear head I typed wwwdotford-trucksdotcom and got the same gibberish as you got, I clicked on it once and took me to the main page then crapped out
I'll be we have some DODGES OUT THERE IN THE WEB, they used to show up for sale every so often,now their probubly just out there Dodgeing around as the would when bored.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1997 Ford Explorer http://www.4TL8Ford.com
Signature Mod Test
On the top of the first post, on the right hand side, is: LOG OUT. If you log out
every couple of days, each time you log out, it will automatically clear all cookies.
Than, follow directions and log in. And your good to go for another few days.
--- REPETE ---
It wasn't a problem with the site, or the cookies, or logging out, or Internet Explorer. It was related to my ISP's DNS Server. It wasn't hooking up right. (I am not a computer geek. I know just enough to be dangerous.)
From what I've been able to figure out, DNS Servers translate the web site description (ie: "Google") into the language the Internet needs to find the site (ie: "64.233.167.147") That's as much as I know about that.
I found the solution by installing a free program called Treewalk (TreeWalk DNS Home). Apparently, this program takes over the DNS Server duties from your ISP, so it's goodby DNS error messages.
Anyway, it's good to be able to access FTE from home again!
I installed it but have not figured out what I need to do to set it up.! Still can't login from home!
__________________
Introducing Toby
WV Chapter Member
He is a long coat sable Chihuahua and the newest addition to the family.
2002 Escape and as fitter said "Wife's Ride", 1999 Mercury Sable "my work ride", 1999 F250 4x4 SD Crew 7.3 "The Beast"
1982 F250 4x4 Known as BullDog! with a 300 l6, Offy "C" and Holley 390 CFM
1960 Austin Healy Sprite MK I (Bug-Eye)
I uninstalled it and reinstalled and now it works on both XP systems.
It does not work on the Vista system and I have not found a way to make it work.
On another tech forum they talked about and some used OpenDNS But all it did for me was lick me in the site and I could not go to any other place on the net!
Will keep working on the problem.
__________________
Introducing Toby
WV Chapter Member
