Anyone using E85 fuel?
#76
Variable compression motors sound nice, but no clue on how that would actually work. Now a Flex fuel Ecotec motor would be the cat's meow, since you can vary the effective compression ratio with a turbo by increasing the boost to the motor. A turbocharged FFV is the holy grail IMO.
But an FFV EB would be very nice.
#77
CORN: gov't subsidizing ensures that more people grow corn for fuel. therefore not enough "food" product is grown...and that causes us to actually import food
this way, the farmer gets paid an inflated amount to grow a crop that we could do without instead of growing a useful crop
OIL: you finance the latest building in Dubai
which is funny since we have such a plethora of oil sources locally we could exploit. the green movement can be thanked for that
damned if you do, and damned if you don't ...I wish people would wake up and smell the coffee about these "green" fuels like E85. It isn't green, and it costs just as much as oil. I guess if you slap a green leaf sticker on it though, it must be earth friendly.
#78
either way you go, the money is going overseas.
damned if you do, and damned if you don't ...I wish people would wake up and smell the coffee about these "green" fuels like E85. It isn't green, and it costs just as much as oil. I guess if you slap a green leaf sticker on it though, it must be earth friendly.which is funny since we have such a plethora of oil sources locally we could exploit. the green movement can be thanked for that
So if you think E85 is a useless crop, how do you think we'll ever reduce or end our dependence on foreign oil? E85 is a stepping stone. E85 only vehicles get much better mpgs and produce more power than a gasoline only motor. Plus, corn is a renewable resource, fossil fuels are not. Think switchgrass, sugar cane, sugar beats and cellulosis (sp?) are few items they can use instead of corn. Problem is there isn't enough E85 around the US yet to build cars that only run on E85, which they must then reduce the cars compression to run gasoline, ruining the benefits you'd get from running an E85 only vehicle. Get these other products up and running, E85 more across the US and you won't need to subsidize.
Huh? I only purchase gasoline from a station that does not use Middle Eastern oil. Even the gasoline they put in the E85 I use is not from the Middle East. I've done research on the two stations I frequent.
Hey, I'm not a green person. Just try to do my part for the country and world as a whole when possible. So I agree the greenies have impacted our ability to drill locally, but I'm not supporting their views.
It may cost just as much as oil, but we don't have to support the middle east to produce it, less pollution, it can be reproduced over and again, it helps local farmers, and many more reasons.
So I'll agree to disagree with you. I've done plenty of research on E85 and agree in it's current state it's not the greatest, but it's a stepping stone and stage one of moving away from oil and supporting the middle east.
#79
soapbox/
E85 is the biggest government boondoggle ever. ADM paid millions to politicians on both sides of the aisle so that ethanol would be pushed on the public and required to be mixed into our gasoline. It takes more energy to make a gallon of E85 from corn than you get out of the completed product.
E85 is not green in any way. It's the typical BS "green" crap that's fed to the masses to make money for someone. The people perpetrating this BS don't care about the environment. It's just another way to redistribute wealth.
Whew! Sorry about that! /soapbox
#80
So if the facts that Ethanol is a bad alternative for fuel and also as an gasoline additive, what are the alternatives? Is MTBE better to mix instead of Ethanol? I know there is a 2008 Hyundai recall because the fuel pumps are failing because of corrosion from the 10% ethanol per volume on gasoline. Maybe this stuff is really bad for our cars in general.
#81
Going oversees, maybe so on certain products, but not gasoline. When was the last time you saw huge corn crops in Saudi Arabia, Iran or Iraq?
we are importing wheat and other staple crops to feed our own people. it may not be the Oil rich countries seeing that money directly, but the money is leaving the USA. either directly from Oil purchases, or indirectly from food imports
by using what we have locally. ethanol is fine, but the hype has been used to cover up the bad aspects of ethanol as a fuel additive. between Alaska, Canada, South America and our offshore rigs, we could completely wean ourselves...or at least reduce the dependancy to a point where it wouldn't affect our supply lines every time some jihadist sets off a bomb...but politics are a mother'fer
on one hand you say E85 gets worse mileage...and then you say something like the part above. Which is it? E85...or any ethanol mixed fuel has a lower energy content than regular unleaded. fact. you will burn more E85 than conventional gas. Undisputable
to achieve a car revolution with e85 as the only fuel source and the engines that utilized this to the max extent possible will never happen. We'll see souped up Gold Carts on the highways long before that happens...wait, they already are here
South America can get away with growing those food crops for fuel usage. Our agricultural industry would require a complete retooling to achieve that. I have heard there have been breakthroughs with using algea that produce several times the amount of ethanol that corn does. if this proves viable, e85 could become alot more prevalent, but until then...
that is funny. oil goes to only a few refineries...it then goes to the different companies. you're running Arab oil...maybe not 100%, but it's in there
Government: Energy Information Admin
#82
bold stuff
bold stuff
Ethanol is most commonly used to power automobiles, though it may be used to power other vehicles, such as farm tractors and airplanes. Ethanol (E100) consumption in an engine is approximately 34% higher than that of gasoline (the energy per volume unit is 34% lower).[14][15] However, higher compression ratios in an ethanol-only engine allow for increased power output and better fuel economy than would be obtained with the lower compression ratio.[16][17] In general, ethanol-only engines are tuned to give slightly better power and torque output to gasoline-powered engines. In flexible fuel vehicles, the lower compression ratio requires tunings that give the same output when using either gasoline or hydrated ethanol. For maximum use of ethanol's benefits, a much higher compression ratio should be used,[18] which would render that engine unsuitable for gasoline use. When ethanol fuel availability allows high-compression ethanol-only vehicles to be practical, the fuel efficiency of such engines should be equal or greater than current gasoline engines. However, since the energy content (by volume) of ethanol fuel is less than gasoline, a larger volume of ethanol fuel (151%) would still be required to produce the same amount of energy.[19] In spite of that, as the ethanol-only vehicle wastes less energy, yielding the same or higher mileage.
#83
#84
#85
true
the ethanol is even more so. running a higher concentration of ethanol in a non FFV vehicle will cause leaks/failures long term. The FFV vehicles have different seals and lines to resist the higher corrosiveness of ethanol.
#86
That depends on what you mean by non FFV. If you are talking about 70s carb'd vehicles, then yes. Newer vehicles can handle the ethanol in the tanks and lines.
#87
Upto what concentration? There have been some people who have been putting in E85 and having failures as soon as the 2nd tank. Hyundai fuel pumps are being damaged by even 10% or less.
#88
My Brother-in-law just bought himself an '06 F-150 Super Crew 4x4 with a 5.4 liter that runs on flex fuel and he seems to be getting around 14 MPG on the highway and 12 MPG in the city using E85. He is thinking about getting a bed cap for it and see if the milage will increase. My truck's 5.4 liter does not run on E85 because its not equipped with the flex fuel engine. I heard if you attempt to run E85 in a non flex fuel engine, the burnt bi-products of combustion from ethenol are very acidic and will attack the metal in critical engine parts, thus greatly reducing engine life between overhauls. I think the flex fuel engines use special coatings on these critical engine parts to extend their life from the acidic effects of burnt bi-products of ethenol if I'm not mistaken.
#89
