fuel lines
Old 03-30-2008, 03:17 PM
kenpobuck's Avatar
kenpobuck
kenpobuck is offline
fuel lines
I am converting my 88 Bronco over to a 6.9 idi this summer and plan to make and run BD. My fuel lines right now are kinda cobbled and I am gonna rerun them and was wondering if aluminum is safe to use with BD? I ask only because I think I read on here about some metals reacting badly with BD. Thanks for the help.
Old 03-31-2008, 12:00 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
You better be carefull
I doubt that the Bronco's suspension can handle the weight of that diesel.
Old 03-31-2008, 03:44 PM
kenpobuck's Avatar
kenpobuck
I am swapping it all. Springs axles etc..
Old 04-03-2008, 03:20 AM
misnomer's Avatar
misnomer
misnomer is offline
As I recall in reading a report stainless steel was the least reactive metal and aluminum was next on the list then mild steel. Then ones they "report" as being reactive are copper and brass if I am remembering correctly. But that was mostly looking at VO and polymerization. With BD it is less of a concern, but you will want to replace your rubber lines with something else. viton hose works
Old 04-03-2008, 08:02 PM
kenpobuck's Avatar
kenpobuck
Thanks, I knew about he rubber but was unsure of the metals.
Old 04-08-2008, 07:32 PM
stevilknevil's Avatar
stevilknevil
stevilknevil is offline
be sure you have plenty of filters on hand.that bio diesel shure scrubbes the crud out of a fuel system.
Bathurst
1999 to 2016 Super Duty
10-08-2012 10:57 AM
Midwest Dually
Bio-diesel, Propane & Alternative Diesel Engine Fuels
18
05-16-2010 10:24 PM
sundy58
04-06-2008 01:02 PM
polar88
Computer Chips & Tuners
03-07-2005 01:11 PM
Quick Reply: fuel lines
