Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-30-2008, 11:51 AM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
Garage is empty, add now
rmalottwtes30 is gaining momentum as a positive member of FTE.
making biodiesel
I found online how to make a sampe batch of Biodiesel, it said all i need is methanol, lye, and oil. Ok here come the questions
What type of oil do I use?
Where can I get lye?
I know that that HEET stuff for gas lines has methanol, is that what I use?
Also do I need to do anything to my truck if I do run Biodiesel in it? They have some at a local BP and its almost the same price as diesel...I just want to try it and see. So is it just a fill up and go thing?
Can it be mixed with diesel? or does my system need to be cleaned out?
__________________
Ryan
1994 F350 7.3 IDIT
Dana 60
E4OD
  #2 (permalink)
Old 03-31-2008, 12:03 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
I suggest you check out this site it will answer all your questions
Biodiesel Tutorial Website
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 03-31-2008, 05:55 PM
1994diesel's Avatar
1994diesel 1994diesel is offline
1994diesel is starting off with a positive reputation.
with your truck, no, just be prepared to change your fuel filter more often for the first several tank fulls, by nature biodiesel is a solvent so it will eat all the crap off the inside of the tank and into your filter...
__________________
Justin
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, IP turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
  #4 (permalink)
Old 03-31-2008, 06:03 PM
Phydeaux88's Avatar
Fuel lines and seals made of real rubber could be a problem consider replacing anything easily accessible
__________________
  #5 (permalink)
Old 03-31-2008, 06:11 PM
1994diesel's Avatar
that is true, but isnt that only if you are running b100?
__________________
Justin
  #6 (permalink)
Old 03-31-2008, 11:24 PM
sstipiotis sstipiotis is offline
sstipiotis is starting off with a positive reputation.
Check out also www.biodieselcommunity.org----Use unused veg oil to test frist and you can get lye from Lowes plumbing dept. where the drain cleaners are (ROBEC CRYSTAL DRAIN CLEANER) good enough to test with. Good Luck!
  #7 (permalink)
Old 04-01-2008, 08:36 AM
Phydeaux88's Avatar
I believe, don't know for sure, that any amount of BD will eventually attack rubber components.
Lower percentage blends, B20 B50 etc, will take longer but eventually cause damage.
__________________
  #8 (permalink)
Old 04-01-2008, 10:43 PM
1994diesel's Avatar
ahhh, ok, i guess i need to eventualy change that on my truck, thanks
__________________
Justin
  #9 (permalink)
Old 04-02-2008, 07:25 AM
Knotwild Knotwild is offline
Knotwild is starting off with a positive reputation.
Take a rubber band and drop it in some bio at any percentage and see what it does. I put one in some B100, and it didn't take long to swell up and break with the slightest tug.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #10 (permalink)
Old 04-02-2008, 11:39 AM
Phydeaux88's Avatar
1994diesel
You may already have non rubber lines and seals on your truck. Ford changed to vitron about 1994.
__________________
  #11 (permalink)
Old 04-02-2008, 12:50 PM
empiretc's Avatar
empiretc empiretc is online now
empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.
are you talking about this one:
Make your own biodiesel: Journey to Forever
i am doing this this weekend. i see $5 diesel in the future and do not like it.
__________________
If the lunch meat called spam became the catchword for a depersonalized email message, then social networking should be known as soylent green!
Please, do not text & drive: http://www.youtube.com/watch?v=gRwfq7Igvxc
-David
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
