If the part I believe you are referring to, posting the webpage of 'Restoration Specialties' is the only supplier I have found that carries them. I did not purchase, or inquire about the item, but I have purchase many of the hard to come-by hardware when I reassembled the 65 F100. There customer support is very good, I have sent them items to match and they immediately returned item to compare. From the webpage, open their online catalog and where it notes the page number enter 212 then hit enter on key boards. I had to remove the arm from another vent window I was unable to repair, carefully drilled out the old rivets, did the same with pivot hinges.
Thanks for the info . I wiil check with them in the morning . Looks like they have a bunch of goodies .
Quote:
Do you mean what the window pivots on, or the handle that pivots? If you mean what the whole window pivots on, they do not have it. If you mean parts for the handle you turn to open it, they have those. $30 for the handle, $20 for the piece it goes on, and the spring for $3.
__________________
Charles F. Rives III
65 F-100 2wd-352 4v various mods, pretty quick
83 F-250-Obnoxious 6.9 Diesel on 36's
85 Bronco-still sittin stock, 300 I-6
86 Bronco-Eddie Bauer 408w stroker
Im here...you mentioned 'cracked at the bend' Which part is bad...the upper pivot or ??? the lower pivot/stud that is riveted to the vent frame is straight with splines and threaded at the end...
It's the bottom one with the splines,threads and spring .
That is the part .I'll try Carpenter . Seems I saw a vent frame in some catalogue that was over $100 ,if that 's the case I may have to get creative . Thanks for the info .
Quote:
You are speaking of the part that is on the actual vent frame (lower) where the washers, coil spring and nut attach, right?
That was only sold with the vent frame itself, it was never available separately.
C1TZ-8121608-B .. Right Vent Frame ~ FTE sponsor Green Sales (800-543-4959) has 10 of these, NOS (new, old stock)
C1TZ-8121609-B .. Left Vent Frame ~ Green Sales: Zero.
Fits: 1961/66 F100/1100.
EDIT: Dennis Carpenters obsolete parts website (not his repro parts site) shows a left vent frame...maybe.
Whoever typed the number into the site mistyped a couple of digits, so you'll have to contact them to find out: 800-476-9653.
The number appears on the site as: C1TZ-1211809-B. There is NO such part number, but it's close enough to the correct part number of : C1TZ-8121609-B
