Thinking of making a processor
Old 03-30-2008, 08:16 AM
motoman97's Avatar
motoman97
motoman97 is offline
Is there anybody making bio in Delaware. I would like to get some ideals on making a processor. Would it be better to buy one. Good pics of any home made?
Old 03-30-2008, 08:50 AM
tr0y's Avatar
tr0y
tr0y is offline
I have just started this process and with posting on a biodiesel board most seem to think you can build a better, more cost efficient, processor if you are comfortable with fabrication and plumbing.
People seem to like plans supplied by Murphy's Machines.com if you are going to buy plans and would be interested in splitting some costs I would be interested or if you wouldlike to join me I am open to that.
Old 03-30-2008, 09:06 AM
sstipiotis's Avatar
sstipiotis
sstipiotis is offline
Check out www.biodieselcommunity.org Theres plenty of info and diagrams to build your processor with out buying plans. Im building one now and its easy. If your lucky you sometimes can find a used electric water heater which you need for cheap or free.
Old 03-31-2008, 06:04 PM
motoman97's Avatar
motoman97
Thanks I think I am going to build instead of buy first. You are right, it does not look hard.
Old 04-03-2008, 02:50 AM
misnomer's Avatar
misnomer
misnomer is offline
I was going to get a few drums and some tanks to get started fabricating a BD setup. I was just planning on working with 55gal drums ($12ea for the open head drums). $55 for a drum with a cone bottom welded on it. Also for $35 I found a guy making a fitting to fit the 2" bung on a drum and threaded two 3/4" NPT ports.. install a pipe down into the drum and connect your pump to draw the oil up and connect to the other port for a simple way to mix. Add a inline injector to feed your methodixe. You can also get a tee connector ($10) where you could install your electric heating element inline with the pump then no need to weld a bung on the side of the drum.
But he also has 3 120gal propane tanks that have been washed out with acid.. $300 for all three if I wanted to go that route instead. Would it be worth it? Heavier guage steel and would allow larger batches. I was also thinking wouldn't a propane tank work well for collecting? Use a vacuum pump to draw the air out, then when collecting simply slowly open the valve to suck up the oil, then connect the compressor back at the shop to blow the oil out. No need for a pump and no worries of wearing a pump out.
I actually saw a electric water heater thrown out by the trash behind a restaurant.. what would you need one for? The elements are cheap, I can get a 18" long (doulbes back) 220V 6000W for $16 (put 110V to it and effectively you have a 2000W heater with a large surface area)
The part that I am not sure about how to design is the meoh recovery. I have seen a few diagrams but I still don't see how to do it in a way that makes for simple and straight forward operation. Also the water wash.. where am I to put all that water? The shop doesn't have any drains, and the house in on septic so I wouldn't want to be filling it with water. Do I need to build settling ponds? Or is the volume less than I am imagining it to be?
Old 04-03-2008, 10:29 PM
motoman97's Avatar
motoman97
I was looking in to getting a processer from beachbioinc.com looks good and comes with the purolite filter. I have the know how to make one if I just could find one to look at. I am a diesel tech for a large rental company and allready have plenty of equipment to test on.
Old 04-03-2008, 10:51 PM
bobrl13's Avatar
bobrl13
bobrl13 is offline
check this guy out highlandbiodiesel.com I just ordered one.
Old 04-04-2008, 07:38 PM
motoman97's Avatar
motoman97
Look at this one at beachbioinc.com. 1499.00 with purolite drying sys no water
Old 04-04-2008, 08:53 PM
bobrl13's Avatar
bobrl13
bobrl13 is offline
Its like buying a computor, you study, study, study, then purchase, and never look back.
Old 04-04-2008, 10:05 PM
motoman97's Avatar
motoman97
you are so right!! But I am going the biodiesel sys soon as 4.00 gal is at my limit
Old 04-04-2008, 11:31 PM
bobrl13's Avatar
bobrl13
bobrl13 is offline
check out theese tanks - Plastic-Mart -
here's where you can find koh Traditional Tanner's Supply: Potassium Hydroxide wood-ash equivalent 50 lbs
I found methanol at a local go cart shop $283 a barrel
Old 04-11-2008, 09:42 PM
Marianna2003's Avatar
Marianna2003
Marianna2003 is offline
The best information I could find was at Biofuels: Journey to Forever - how to make your own clean-burning biofuel, biodiesel from cooking oil, fuel alcohol, renewable energy, glycerine, soap making. They're in it for the knowledge not profit. They discuss different processes to make Biodiesel as well as the benefits and drawbacks of each.
Old 04-12-2008, 06:32 PM
I'M DK's Avatar
I'M DK
I'M DK is offline
I just posted in 2 other threads on Biodiesel.
It looks like the same info could be useful here.
Welcome - Collaborative Biodiesel Tutorial Website
biodieselbasics : Biodiesel Basics
Biodiesel & SVO Forums - Powered by eve community
Here's a few online retailers.
B100supply.com, Biodiesel Equipment and Supplies
Utah Biodiesel Supply - Biodiesel Homebrewing Supplies, Equipment, Processors and Information
BiodieselWarehouse.com
One other thing.
I wouldn't bother with Journey to Forever.
Seems to be a lot of outdated and some incorrect info there, IMO.
Dk
munireusa
02-15-2020 09:55 PM
Hotwheelbill
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-08-2014 11:56 PM
gman97005
Computer Chips & Tuners
06-06-2013 06:56 PM
Bret (OH)
2009 - 2014 F150
07-06-2012 10:58 AM
Rushmore X
04-02-2009 07:05 PM
Quick Reply: Thinking of making a processor
