1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2002 Navigator air suspension sagging rear
Old 03-28-2008, 07:52 PM
ejjones55's Avatar
ejjones55
ejjones55 is offline
My '02 Navigator just started sagging in rear. I know this is common problem with the air ride. Here is something weird, I am currently selling the SUV and let a guy test drive it for about 15-20 mins. I was not in the Navi with him. He brought it back. I got in it today and realized it was riding funny. CK Susp light went on. I checked the switch under glove box, it was on. I turned it on and off. I don't think the pump is even turned on, I don't hear it.
I don't think the guy did anything to it, but it just was weird!
I am hoping a fuse????
Any help...
Old 03-29-2008, 09:51 AM
ejjones55's Avatar
ejjones55
Update, I drove it around today and could hear the pump kick on, but the rear is still low and now moving at all.
Old 03-29-2008, 06:11 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
Your Navi is a little young to for the rear springs to have worn out but stranger things have happened. If the compressor is running and the rear won't raise, there's a pretty good leak somewhere.
Did you ever notice it dropping when parked overnight?
Leaks in the air springs are, by far, the most common problem. Have someone put it on a lift and let the axle hang. Look closely at the springs for cracks, tears, or other damage. If all looks good, check all of the air line connections with soapy water with the compressor running. (Kids bubble liquid in a spray bottle works great for this). Make sure the lines are all connected.
If it is below freezing outside, moisture in the dryer could have frozen and is blocking airflow, but this would indicate other issues with the system too. The vent valve in the compressor could also be stuck open.
Old 03-30-2008, 08:26 PM
Mark62's Avatar
Mark62
Mark62 is offline
What about my 99?
The compressor runs forever.
Old 03-31-2008, 06:07 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
Originally Posted by Mark62
What about my 99?
You are at about the end of the life expectancy on the rear air springs. Get it checked out quickly. The compressor is not intended to "run forever" and will very quickly wear out, adding $$$ to the repair.
Old 03-31-2008, 08:16 PM
Jugger's Avatar
Jugger
Jugger is offline
my compressor had starting turning on more frequently than usual so i looked at my lines. i found one cut in two.
Old 03-31-2008, 10:51 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
That is very possible, but it's also very uncommon. That's why an initial visual inspection is important before intense troubleshooting. Spring failures are the most common failure, but anything "can" happen. Don't jump to conclusions.
Old 04-02-2008, 10:27 PM
Mark62's Avatar
Mark62
Mark62 is offline
Where do I get the air springs?
2 places I have found:
New rear air spring assembly. for 1997-2002 (4 wheel drive) Expedition
Suncore Industries - Ford Expedition Air Suspension Parts and Conversion Kits
for the 44.00 difference I would rather get the "lifetime warranty" set.
Old 04-02-2008, 11:08 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
You could try the Dealer. They're about $250 each. They are the original Firestone air springs that lasted ~10 years.
For aftermarket. I would recommend Arnott for quality, only because I'm not familiar with Suncore. I have Arnott parts in service that are 7 years old with 0 failures.
Rememer, "The price of quality parts is forgotten long after the warranty runs out". Buy the cheaper ones, but plan on replacing them again while you own the truck.
Old 04-04-2008, 10:34 PM
Mark62's Avatar
Mark62
Mark62 is offline
I bought the Arnott springs because of the lifetime warranty,
and yes my expy starts dropping as soon as I turn the key off...
Old 04-11-2011, 06:34 PM
yankee1911's Avatar
yankee1911
yankee1911 is offline
Navigator air supension
I just repaired the air supension on my 2002 navigator. the problem was the compresor relay located under the compresor. (Lay on your back and look up behind the front passenger side light.) $102 from ford dealer. CAUTION: the trobleshooting tip. "Does the car lower when turned off?" is not the best indicator of a problem. This is normal in the navigator for ease of entrance. Chech the owners manual.
Old 07-13-2011, 09:32 PM
Josh888's Avatar
Josh888
Josh888 is offline
I have a 2000 Navigator 4WD. The rear end dropped just out of the blue and the air suspension motor does not come on. I ran power directly to the air suspension motor and it runs fine, So I replaced the Module and the motor still does not come on. I replaced the rear hight sensor and still nothing. I jumped the motor to run it and aired the rear end back up. But I cant get the motor to come on. There is and has been a slow leak in the air line so the air suspension motor used to run everyday twice when i would start it for about 30 seconds. Any ideas why the motor will not come on? I checked all of the fuses. They are good
Old 07-13-2011, 09:52 PM
alloro's Avatar
alloro
alloro is offline
Received 4,201 Likes on 2,436 Posts
You replaced the air suspension module or the pump relay?
Old 03-03-2016, 04:45 PM
bbad's Avatar
bbad
bbad is offline
were you just not getting power to the pump
Old 03-04-2016, 12:17 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,165 Likes on 920 Posts
Welcome to FTE
Not sure if you realized the last post was in 2011?
Quick Reply: 2002 Navigator air suspension sagging rear
