Thirsty for Brake Fluid...
Alright, another problem for the truck... seems to be drinking brake fluid. I topped it off about a month ago, and it's down about an inch now. No puddles under the truck. Dumb question, but where do I start looking? I should have time this weekend to look at it, just need to know where to start. Thanks!
-Robb
-Robb
wouldn't you be able to see fluid around the drum if the wheel cyl. were leaking??? and you will lose some as the shoes wear in these trucks especially cuz of the size of the pistons and calipers...... cuz the pistons are out farther... meaning there is more fluid in the calipers... just think when you change shoes and compress them back most of the time it will run over... been there done that... but i need to check under my truck i have the same prob... and it started after i replaced my brake lines... but i have checked them before and not seen any leaks... but i still think there is a leak somewhere...
you dont always see the fluid. a lot of times it gets evaporated from brake heat before it makes it to the outside. i have this same issue right now however i know where my leak is... on the front pass side caliper, one of the brass seals got mangled in my last front axle teardown and have not had a chance to get back in there.
-cutts-
-cutts-
-cutts-
-cutts-
