#1 blend?
Old 04-30-2008, 11:36 PM
nhill2090's Avatar
nhill2090
nhill2090 is offline
#1 blend?
Wanted to give biodiesel a try today while I was out in the direction of the only station around ( about 30 mins away).
Pulled up and it said straight #1, 50% #1 50 % #2, 25% #1 75% #2 and straight #2. Is this the same as 100% bio, 50 percent bio, and 25 % bio or am I totally off track.
Sorry guys I'm new to this scene.
Old 05-01-2008, 12:05 AM
Pocket's Avatar
Pocket
Pocket is offline
#1 is closer to kerosene, #2 is standard diesel. Winter blend diesel is a mix of #1 and #2. #2 diesel has higher BTU's, and is typically the fuel that you run during the summer months. #1 diesel has a lower energy content (BTU's) and also less lubricity. This causes a loss of power and a drop in mileage. The reason #1 diesel is blended with #2 during the winter is because of the gel point. #2 diesel will cloud or gel quicker than #1 diesel. In cold weather, you don't want your fuel to wax up or you'll never get your truck started. By adding #1 to the mix, your fuel won't gel up (unless you're in Alaska or something).
Bio is always indicated by the letter "B" followed by a number, and is rated as these examples:
- B2 (meaning 2% bio diesel, 98% diesel)
- B20 (meaning 20% bio diesel, 80% diesel)
- B100 (100% bio diesel, no regular diesel added to the mix)
Bio can be any blend and range from B2 to B100 and anything in between. Just B2 alone gives more lubricity than any fuel additive you can buy.
Hopefully this clarifies a few things.
Old 05-01-2008, 11:11 AM
nhill2090's Avatar
nhill2090
thanks Pocket, im justwondering why the gas station advertises biodiesel yet i didnt see it at any of the pumps
so now i basically have winter blend fuel again that will eat away my mileage
frdf250
Bio-diesel, Propane & Alternative Diesel Engine Fuels
06-07-2011 04:27 PM
6.0superduty
03-28-2008 12:20 PM
sand1
01-09-2008 05:02 PM
mongo75
37
06-26-2007 11:14 AM
dumas
Alternative Fuels, Hybrids & Mileage
03-25-2005 10:39 AM
Quick Reply: #1 blend?
