84 f250 starts then dies
I assume this is a 460 motor with the "Hot Fuel Option" using electric pump(s). If so, just because the clear filter is full doesn't guarantee the pump is running in "Run". The pump "Start" circuit fills the carburetor float bowl. Once the motor starts, the Pump "Run" circuit is supposed to take over and continue to supply fuel at a slightly reduced rate. If there is a problem in the pump "Run" circuit, then the motor only runs long enough to use up the fuel previously pumped to the float bowl.
bashby
08-20-2021 05:40 PM
Matthew Wilson
13
01-05-2016 12:07 PM
nerdpcr
13
12-31-2014 05:15 PM
00RANGER/76F250
03-26-2008 10:40 AM
