Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-22-2008, 11:09 AM
DonaldL396 DonaldL396 is offline
Garage is empty, add now
DonaldL396 is starting off with a positive reputation.
E350 gas mileage
Doing some research on vans before I buy.
What kind of real life gas mileage can I expect out of a 2007 e350 with a 5.4 and a 3.55 gear. I will not be towing. Im drive mainly on flat highway.
thanks
  #2 (permalink)
Old 03-22-2008, 01:05 PM
YoGeorge YoGeorge is offline
YoGeorge is a name known to allYoGeorge is a name known to allYoGeorge is a name known to allYoGeorge is a name known to allYoGeorge is a name known to allYoGeorge is a name known to all
thanks
I've got an '02 E150 conversion with a 3.55 and a 4.6 engine. On flat freeway runs with a fairly light load (4 people, bicycles and luggage), I can count on 17-18.5 mpg, and that is not driving slow. I'd bet I could hit 20 mpg driving 60, but just *can't* bring myself to do that.
I've got a spreadsheet which tracks my gas mileage for the lifetime of the van (59k miles) and just updated it--overall average of 16.4. Lots of city tanks in there, and this winter, mileage has really stunk using Michigan winter gas.
With an E350 and the 5.4, I'd guess you could count on 16-18 on straight freeway runs, depending on your load and your speed, and assuming summer gas.
George
  #3 (permalink)
Old 03-23-2008, 11:02 AM
Thanks for the input. I want an e150 but the e350's are everywhere and at some great prices. I just didnt want any gas mileage suprises. Above 15 hwy is acceptable. thanks again
  #4 (permalink)
Old 03-23-2008, 11:43 AM
Genesis Genesis is offline
Genesis is starting off with a positive reputation.
E350
With the E-350 you may get gas milage surprise. They weigh more and obviously what you put in it will be a huge factor. Mine gets 9 city, 13 Highway with a full load(7,000lbs) but it is a V10. The 5.4 does get better MPG.(but not as much as you'd think). Have you considered an E-250 as a happy medium. Good luck with your purchase.
__________________
2003 E-350SD, V-10, 373LS, 4R100, 3" rear lift, Diablo Tune
  #5 (permalink)
Old 03-23-2008, 06:22 PM
kgwld1 kgwld1 is offline
kgwld1 is starting off with a positive reputation.
Wink
My van e 250 extended 5.4 3.55 rear avg. 17.4 for the(95,000) life of the van. 17-19 is the norm, I use this for my expediting bus. and think the milage is pretty darn good!
  #6 (permalink)
Old 03-25-2008, 07:08 PM
thanks for the responses guys. An e-250 would be perfect but they must not make it anymore, in the club wagon. My problem is that an e150 is a little lighter than i wanted and a e350 is heavy for my needs. I thought about a e150 with overload springs or air bags. thanks again
  #7 (permalink)
Old 03-26-2008, 05:23 PM
E250HDSuperVan's Avatar
E250HDSuperVan E250HDSuperVan is offline
E250HDSuperVan is starting off with a positive reputation.
My 1995 E250 SuperVan was getting 10 MPG, dropped to 8 in the city over the winter.
Found a leaky filler tube and a plugged filter - hopefully it improves.....
__________________
Steve
www.motohorseman.forumotion.com
  #8 (permalink)
Old 03-26-2008, 05:47 PM
5.8l
Is that the 5.8l or 5.4l. Don't remember when they made the change. The 5.8l can be brutal but the 5.4l should do closer to 12 I would think. The extended obviously weighs more so that's an issue too.
__________________
  #9 (permalink)
Old 03-26-2008, 06:17 PM
5.8l, the old 351W I believe.
And it's been tuned up, at least plugs/wires/cap/rotor/filters not that long ago.
__________________
Steve
  #10 (permalink)
Old 03-27-2008, 10:45 PM
kips kips is offline
kips is starting off with a positive reputation.
2005 e350, avg'd 12.7mpg,highway from houston-dallas last weekend, speed 70-80mph. I would guess 13-14 should be attainable @ 65-70mph.
  #11 (permalink)
Old 03-27-2008, 10:46 PM
oh forgot, 2005 e350 5.4, 3.73
  #12 (permalink)
Old 03-28-2008, 05:20 PM
Sounds right
Quote:
That's an honest MPG report which is refreshing. These trucks don't get close to 20MPG on the highway unless they're empty and going downhill. Not an E-250 or E-350 with the 5.4. Vans are so non-aerodynamic that good MPG's is just not happening.
__________________
  #13 (permalink)
Old 03-28-2008, 05:32 PM
Do you own mine this is my 2nd one and my milage is what it is! I drive with this van for a living and I stand behind my milage. My miles are 99% highway I get 600 plus miles per tank.
  #14 (permalink)
Old 03-28-2008, 06:12 PM
The million mile van guy says he averages 15-18....
Quote:
The expeditor fella who has over a million miles on an E250 with a 5.4 says he averages about 15 mpg in the winter, 18 mpg in the summer.
http://www.millionmilevan.com
The blurb on the mileage is on his little message board. I would say that his sample mileage is about as extensive as could be possible; he's run a *few* tanks thru that van, for sure....
George
  #15 (permalink)
Old 03-28-2008, 06:19 PM
My 1st van had over 500,000 miles on it and it got about the same milage as this one.
Tags
1995, 1999, 2007, 2009, 54, bus, e350, estimates, ford, gas, mileage, mpg, real, v10, vans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
