Cylinder misfire '98 F150 4.2L
Old 03-20-2008, 12:26 PM
roperjoe's Avatar
roperjoe
roperjoe is offline
One more question guys:
I have been pulling a code for a little over 1 year now thats showing a Cylinder #2 misfire. I don't notice the miss, so its not missing hard. I pulled the plugs, regapped them, then replaced them, with no change. Then I pulled the wires and tested them, and replaced them to be safe. No change. Then I replaced the Coil Pack just to be sure, and no change. Anyone have any clues as to what else might be causing this? The only other thing I think it could be is a clogged injector in that one cylinder. Thoughts? Thanks for the advice.
Old 03-20-2008, 04:20 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
What is the code number?
Old 03-20-2008, 04:33 PM
roperjoe's Avatar
roperjoe
roperjoe is offline
Sorry about that....its the P0302 code. Thats the only code I am getting. Thanks.
Old 03-20-2008, 04:41 PM
BlueOvalFitter
It very well could be the injector.My friend was getting code P301 and it turned out to be a cracked plug.
Try pulling the electric connection to that injector and see if changes.Don't keep it unplugged for long due to possible hydro-locking it!
Old 03-20-2008, 04:44 PM
88FordF-150's Avatar
88FordF-150
88FordF-150 is offline
Yep id say your next culprit is the injector, though you said its running good, and if the injector stoped working then you would know.
Old 03-20-2008, 05:51 PM
roperjoe's Avatar
roperjoe
roperjoe is offline
Maybe the injector is working, just fouled up??
Old 03-20-2008, 05:57 PM
Pinksforslips's Avatar
Pinksforslips
Pinksforslips is offline
You might want to clean out the carbon build up in the intake by the egr and iac motor.
Old 03-21-2008, 11:54 AM
roperjoe's Avatar
roperjoe
roperjoe is offline
Hard to change out a single injector?? Intake is clean.
Old 01-23-2012, 04:15 AM
snatchinfords's Avatar
snatchinfords
snatchinfords is offline
I know this is a late post but here's something for someone in need that is reading this . My 98 4.2 liter was experiencing the same problems described in this forum. Misfire on cylinder 4 replaced plugs wires coil pack the whole nine. After a long trial and error I removed my valve cover to find a bad rocker arm. The pushrod was lodge inside the rocker arm. You would think there would have been a lot of noise coming from the motor but there was actually only a slight ticking sound. Not saying its your issue but it is something to think about.
Old 01-24-2012, 08:37 PM
FORDSVTPARTS's Avatar
FORDSVTPARTS
FORDSVTPARTS is offline
Former Vendor
Thanks for the info. I have a 99 with a #6 misfire, with the same parts having been replaced. I pulled the #6 plug, and look OK as well
It still seems to run good, but its definitely something for me to check.
-Mike R
C&W Auto and Diesel
2004 - 2008 F150
105
05-11-2019 08:35 PM
priorityautorepair
Escape & Escape Hybrid
12-15-2014 06:51 AM
ParisDakar
1997 - 2003 F150
08-23-2012 01:40 PM
smotherss
2004 - 2008 F150
03-15-2010 08:48 AM
Schooner 45
Modular V10 (6.8l)
08-23-2009 08:45 PM
Quick Reply: Cylinder misfire '98 F150 4.2L
