5.4 f350 sd are they made??????
did ford make any f 350 super dutys with a 5.4l engine at all?..reason I ask is I been looking for a used f 350 super duty with a 5.4l engine but everyone I see is a diesel for some reason.so im guessing I can only get a 5.4l engine in a f 250?in a super duty years 99 to 05?
Originally Posted by f150_514ci
yes i have one its a 2002 f350 5.4 4x4 regular cab and a 6spd. took me almost a year to find it and only saw 1 other for sale in my area. i had to drive 3hrs to go get mine but there out there.
Just curious,
Why do you want a 5.4L in a 350? If you need a 350 I am guessing that you are wanting to do some heavy towing, so why not just get the V10? Virtually no difference in gas milage and more power. Just woundering? I am not ripping on the 5.4 at all because I have it and like it but wish I had gotten the V10.
Originally Posted by ffadragon
Just curious,
Here is a link to teh 2005 towing guide. As you can see they have columns for F-250/F-350 SRW and F-350 DRW.
What you do get with an F-350 SRW is the ability to haul about 1000 pounds more in your bed, compared to an F-250 equipped the same way.
I know that, but most people think you can tow a lot more with a 350 than a 250, so that is what I was thinking he was wanting. I am just trying to figure out why he has to have a 350. If the O.P. is wanting to haul or pull a lot he maybe needs to reallize it doesn't matter if it is a 350 or 250, and that a v10 will suit him better. And be much easier to find a 250 with either engine than a 350 with either engine.
Originally Posted by redford
What you get with an F-350 SRW is the ability to haul about 1000 pounds more in your bed, compared to an F-250 equipped the same way.
ive seen older F350's around with the 5.4L ...
I'd say dont limit ur self to "F350" check out F250's as well for the configuration you want... just my $0.02
Ive got an '01 f350 5.4l cc sb and just love it. i do tow quite a bit and there is plenty of room for the little one and gear. im not gonna win any races towing, but the truck has always been able to maintain on the hills. if i hadnt found such a great deal and jumped on it, i would have looked at both the 250 and 350.
my only concern... i dont know what the year range is for the plug issue, but i know im at risk. (sounds like an std ) that may be one of the hundred things to consider, 'specially when looking at used. make sure you have the history and a good 3rd party look over before buying something you expect to be trouble free
Originally Posted by browntown3
I've got one i'd love to sell you! its in the Classified section of this site... Check it out...might be a long drive from CT to TN though
I've got a 2006 F350 CC with the 5.4l gas. I had been looking for the V10, but could only find the V8. Most of the trucks were diesel, which I did not want. Dealer said that they had a tough time selling the 5.4l V8 because most people want the F350CC for towing, and want the V10 in it.
I rarely tow, but do plow. Have never had a problem with a lack of power plowing with the 5.4; don't even have to use 4lo (has the 3.73 axle). The plow weighs about 1,000 lb, and I carry the same weight in the bed for ballast (sand bags).
I towed a small car (3,000 lbs) on a 12,000 lb dual axle trailer once; the truck really struggled from a dead stop, so the V10 is necessary for easy towing.
I wanted the F350 vs the F250 because I figured that, if I was spending the money, I'd get the little extra suspension capability.
