85 F150 fuelie Runs 15 min then dies
I have a 85 F150 Short box flareside (nice truck). 302 fuelie, built June 1985. I bought it not running. THe PO says hat it runs for 15 min then dies. I haven't tried myself yet. I have tested the TFI module and tests out to be bad on the GND and PIP in, PIP PWr and PIP In fails. I also checked the wiring to the TFI Module . THe haynes manual says the colours are as follows:
Wht-Lt Blu, Blk, Yel-Lt Grn, Dk Blu, Red Lt Blu, Dk Grn-Yel.
My truck
Drk Blu, Yel, Red -Lt Blue, Yel- Silver or Lt Blu (not Sure),Dk Grn, Lt Blu-Blk.
Is this right or has someone played with the wiring. I don't want to put a new TFI module in if I'm going to melt the new one down.
I checked the later years with no luck on the colouring.
Also the PO installed a new TPS.
Can someone help???
THanks Mike L.
My truck
Can someone help???
THanks Mike L.
Pull the codes. They may give you a hint as to what's wrong. Here's a site that tells you how to do it with a regular meter or testlight. www.fordfuelinjection.com
P.S. I got rid of your other post in this forum. Less confusion that way, and we will keep your problem seperate from the other one by using this thread you created.
billyba
10-25-2011 02:30 PM
vagrants
1983 - 2012 Ranger & B-Series
04-29-2011 09:03 PM
