Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-17-2008, 03:03 PM
Willis65 Willis65 is offline
Willis65 is starting off with a positive reputation.
5.4L Bogging
I have a '99 E-150 with a 5.4L. It has 127,000 miles and in the last 2 months I've noticed a drastic reduction in power. You can feel it at all speeds, but it's much worse trying to accelerate from about 30 mph. If you just give it a little throttle it seems to bog, almost like the more throttle you give it the slower it goes. Once it downshifts, it accelerates ok but not great. Brought it to the mechanic and after 2 weeks of checking they decided that the knock sensor is picking up some noise in the bottom end that it's mistaking for a knock and retarding the timing in an attempt stop the knock. It's not the cat, they changed it and it didn't help. It's not the fuel filter or the air filter, both new. The answer seems to be an engine swap. I'm having a little trouble believing that, although I do trust this particular mechanic. I'm looking for alternatives before forking over the $$$. Anybody have any other ideas of other possible causes of the power loss?
  #2 (permalink)
Old 03-17-2008, 03:08 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
Unplug the knock sensor,and see if it gets any better. IMO-there's no reason that the engine should be worn out already-Modulars are tough little engines. I'd bet it's a bad knock sensor.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #3 (permalink)
Old 03-19-2008, 03:50 PM
redford's Avatar
redford redford is online now
redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE.
It does sound a lot liked a restricted exhaust.
Also, did they verify the cam(s) timing was still good?
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73 LS Tow Command
Presently working as a military contractor in Afghanistan.
  #4 (permalink)
Old 03-19-2008, 04:09 PM
Here's a bit of an update. First, they did change the cat but found that it wasn't clogged and the van didn't run any better so they put the old one back on and didn't charge me anything. Second, I picked the van up on Saturday and it drove just as badly as when I dropped it off. On Monday I decided to try locking out the OverDrive to keep in a lower gear to give me a better pick-up. Ever since I locked out the overdrive on Monday the van drives like normal, no hesitation. Could this be a transmission problem and locking out the overdrive that one time somehow changed something?
  #5 (permalink)
Old 03-19-2008, 10:27 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
OD with the torque converter locked will show more defects because the engine has to work harder to accelerate with no converter slippage and the low rpm.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #6 (permalink)
Old 06-21-2009, 06:17 PM
equium equium is offline
equium is starting off with a positive reputation.
Quote:
Did you ever find a solution? I also have a '99 with the same engine and mine just started acting like yours: no power. However, this happended right after a smog check (I passed). I replaced the fuel filter but it was only 20K miles old and it was not clogged. Air filter is fine. I can't stand it. I have 187K on mine. I thought I got some bad gas 'cause I filled up at a "cheapie" place but I've filled up there before (gas and diesel) and never had a problem. So, did you find a fix?
thanks
__________________
99 XLT Clubwagon E150
5.4 Triton
11 passenger
91 F250 XLT Lariat (4X2)
7.3L IDI
  #7 (permalink)
Old 06-21-2009, 10:30 PM
Yes, I did find the problem. It turned out to be a bad coil. After replacing the bad one and putting new plugs it ran great. I began having the same problem again, ended up changing all the coils and putting a fresh set of plugs. Runs great again. Hopefully I won't have to deal with this again.
  #8 (permalink)
Old 06-22-2009, 06:57 AM
rsylvstr's Avatar
rsylvstr rsylvstr is offline
Flt Marine Force Corpsman
rsylvstr has a very good reputation on FTE. rsylvstr has a very good reputation on FTE. rsylvstr has a very good reputation on FTE.
did you buy aftermarket?
__________________
The best battlefield medicine is fire superiority
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Cooper ATR's, K&N Series 77 CAI
Nasta S/S nerfs, Rancho RSX
http://home.rr.com/robandvic
  #9 (permalink)
Old 06-22-2009, 09:29 AM
Willis65: Thanks for the follow up. How did you determine which COP was bad? I just replaced the plugs about 20K ago, so I'm hoping I wont need to. Also, my #4 plug got spit out and my mechanic repaired it. Again, thanks for the response.
__________________
5.4 Triton
11 passenger
7.3L IDI
  #10 (permalink)
Old 06-22-2009, 11:37 AM
I didn't actually determine which one was bad, my mechanic figured it out. They were aftermarket coils from NAPA.
  #11 (permalink)
Old 06-22-2009, 12:02 PM
Thanks. The funny thing is: My van is acting just like it did before my #4 plug was spit out. Sluggish. My mechanic/friend said that if it was another blown plug, i'd know about it. there would be no mistaking it. Maybe this old girl needs a new set of COP's. I'll update this thread with the solution.
__________________
5.4 Triton
11 passenger
7.3L IDI
  #12 (permalink)
Old 06-22-2009, 05:54 PM
Good luck equium. Changing those COP's did the trick for me.
  #13 (permalink)
Old 06-26-2009, 10:42 PM
ExpySport ExpySport is offline
ExpySport is starting off with a positive reputation.
I'm having a similar issue all of a sudden on my 02 Expedition. I'm hoping it's just a bad tank of gas. Plugs & COP's all done 12k ago. New PCV valve about 3k ago. New DPFE sensor & hoses 3 weeks ago. Engine runs great, but it just seems to be bogging down since the last fuel tank fill-up. Used a name brand fuel which I don't usually use, but was on the highway and had to stop for gas. This brand was at the exit. Going to go back to Sunoco next time - Expy runs great on it. Co-worker suggested I run a bottle of fuel system & injector cleaner through just prior to filling up the tank next time.
__________________
Tag
2002 Expedition XLT 4x4 5.4L
Sport Appearance Package
125,000+ miles
  #14 (permalink)
Old 07-07-2009, 01:13 PM
UPDATE ON MINE (EQUIUM):
I took it to my friends house. He drilled and tapped the exhaust just before the CAT. It read 6 Lbs of back pressure. He said it should read zero; 1 Lb might be acceptable. He tested the fuel pressure during idle and while driving and the fuel pressure was fine. We took the CAT off and turned it into a resonance chamber (if you know what i mean). Now there was zero back pressure. But, the van still ran like crap. But here's the kicker: Now the trouble is intermittent! It will start a trip running bad, and in the middle of a trip, she's back to (mostly) normal. I don't think it ever reaches 100% like it was, but it's much better than before. And something else that is puzzling us: Since the CAT is now "empty", the Check Engine light should have come on. Nope, not yet. even after a week of driving it this way, no light. I'll mention to my friend about the knock sensor and see if we can unplug it for testing.
In the meantime, since I just passed smog a few weeks ago, I can start to save up for the next two years for the $1900 CAT from my local Calif. dealer. Personally, I don't know if this van will make it; My wife is ready to kick it to the curb if we can't fix it.
Thanks for reading.
__________________
5.4 Triton
11 passenger
7.3L IDI
  #15 (permalink)
Old 07-10-2009, 09:28 AM
Update on my situation:
I added a bottle of fuel system & injector cleaner prior to my next fill-up. I went back to Sunoco, which the engine just seems to run 100% better on. About half-way through the tank, it's like the engine just came to life. Since then, gone through 4 more tanks of Sunoco (been away on vacation) and the engine runs like a champ again. Guessing it was just a bad tank of gas from the other brand fuel company.
__________________
Tag
125,000+ miles
Tags
2004 , 54 , location , pcv , triton , v8 , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
