Factory GPS Antenna location
Hi All,
I am about to install a factory Navigation Unit in my 2006 F150, is there a factory location for the GPS antenna? It appears to have a clip on it. I have not taken anything apart yet but I figured I would ask since I know some of you have done this installation already.
Thanks.
Thanks.
I had the same tradeoffs, The deciding factor was that with the factory unit you can play music while using the navigation, with the Pioneer it is one or the other. Also I want the factory look, and it should be less of a theif target since it only works in Fords. I ended up paying $690.00 on Ebay.
I was looking in that area above the radio today, I am glad to hear that it works fine I hate to take apart my dash also an possibly cause rattles. I plugged it in and it powered up displayed the Ford logo then and shut down, I think it needs programming, I will bring it over to ARC on Friday and have it done.
One other thing, I mounted it in the dash, when I but the bessel back on I noticed the unit sticks out a small amount is this normal or do I need to modify some brackets to make it flush. The ebay description said it was removed from an 08 expedition. I am not sure if there are different mounting brackets for the various vehicles it is used in.
Thanks for your help
My nav also came from an 08 expedition and had the same issue. I can't remember what exactly I had to cut but the guys at arc should be able to tell you. what part of MA. do you live in. I'm in waltham about 10 min. from arc. also did it come with the nav dvd? If it did not you will need the 6p disk as older versions will not work with the 08 nav. Jason
I now live in Framingham but use to live in Newton, I am very familiar with Waltham my father had a shop there.
It did not come with the nav CD, I did not know that the newer Navigation units would not work with older versions of the map I bought a 4p version off of Ebay. OOPS!! I figured they were all compatible.
Did the Nav mount flush in your truck? or does it stick out a tad?
Doing this will let the radio sit back about 1/8" further back.........which is perfect.........the plastic trim panel will hide all of your mods.......
This mod is very easy to do...........takes all of 10 minutes........
If you ever decide to remove the nav unit and reinstall the factory radio.....just use some washers under the mounting tabs under the radio to bring it back to the original thickness............
Any questions?
