Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-16-2008, 10:59 AM
lazerf250 lazerf250 is offline
Garage is empty, add now
lazerf250 is starting off with a positive reputation.
08's???
I was curious if you can run the new 08 powerstrokes and duramax's off of biodiesel?
__________________
1997 F 250 cc, sb Extra leafs front and back, Dana 60, Afe intake, 3" downpipe, 5" exhaust, Tony Wildman 6 pos, 250cc Hybrids, Arp Studs, Modded h2e, Built tranny, 17* hpop, Snow Plow and Wooden sides...
  #2 (permalink)
Old 03-16-2008, 11:02 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Ford and GM say yes..........But no more than B-5 or you will void the warranty.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 03-16-2008, 11:08 AM
i was curious about b100, just if it will run fine with all the egr and stuff dont care bout the warranty. do you know if gmc has the same b5 warranty thing?
__________________
  #4 (permalink)
Old 03-16-2008, 11:55 AM
1935 Ford pickup
Quote:
I haven't found any studys on the 08's but I've met 2 guys that use B-100 in there 07's with 0 problems. Yes GMC only recomends B-5..........
__________________
  #5 (permalink)
Old 03-17-2008, 06:09 PM
6.0superduty's Avatar
6.0superduty 6.0superduty is offline
6.0superduty is starting off with a positive reputation.
My buddy runs B100 in his 07 Dmax and he said the only thing he had to do was replace the lift pump because of some sensor or something didnt like the bio. Other than that, it runs fine.
Kyle
__________________
04 crew cab 6.0 4x4
train horns
SCT XCAL2 from Matt @ Spartan
remote start
5" lift with 35's
traction bars
4" MBRP turbo back straight piped to 6" single stack
some other pullin goodies
  #6 (permalink)
Old 03-18-2008, 08:21 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Guys it is time to repeat this again.
The B5 recommendation comes from EMA (Engine Manufacturers Association) and stems from the lack of ASTM standards for BioDiesel. It is not the truck makers that set the max percent at 5%, they were following industry guidelines.
The reason B5 was chosen is because if the BD meets the standard for use in blending at the 5% level the blended fuel still meets the standard for #2 diesel.
As ASTM gets closer to finishing the standards for higher percentage blends you should see those percentages rise, it is already happening in some industrial use engines.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 03-18-2008, 10:27 AM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
http://www.biodiesel.org/resources/f...arranties.shtm
http://www.biodiesel.org/pdf_files/B...ment_32206.pdf
Here is everything you ever wanted to know. Grab a recliner and a pot of coffee and enjoy the read.
__________________
2005 F350 6.0 lariat supercab 4x4 long bed zf6 speed and a real work horse--Burning B100 on nice days and B50 when there is a chill in the air
Mod's-BD exhaust brake-Dura flaps-Piaa back up lights-C-Betr mirrors
-Midwest short throw shifter-Splitz lift-Wilson cell antenna & Amp--Isspro ev gauges-fuel-pyro-ebp
1999 EB expedition (Wife's)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
