351M/400 oil pans?
351M/400 oil pans?
Hi,
If you buy a reconditioned pan from a parts store make sure the oil drain is in the right spot! This weekend I bought a pan for my 351M, put it on the engine then discovered that the oil drain is in a different spot! (I think the pan I got was from a Bronco that had a different engine crossmember location)
This means that when I remove the oil drain plug now, the oil will come out of the pan, hit the crossmember, and make a big mess.
-Brents
-Brents
351M/400 oil pans?
glad to see im not the only one with ?'s about the rear sump pan. i have been trying to order a chrome pan for my 400 to go into my 65 f100. the salesman is saying i need a rear sump and that all pickups and vans (2 and 4 wheel drive)must have a rear sump. will a front sump work for me?
thanks in advance
thanks in advance
351M/400 oil pans?
