You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My buddy told me about a guy that has been making BD for the past three years and runs it in his 7.3 with no problems. I decided to try some. It contains 20% #2 and the rest is BD made from WVO. I have burned about 4 gallons so far and the truck runs perfectly. The only questions I have are, is BD suppossed to be just slighty thicker than #2? It seems like my fuel pump might be about 1 or 2 decibles louder (hardly enough to notice). Also, the fuel is not clear like #2. Is all this normal? Anything to worry about or change? I have an 04 6.0 with 50,000 trouble free miles. Thanks
Kyle
__________________
04 crew cab 6.0 4x4
train horns
SCT XCAL2 from Matt @ Spartan
remote start
5" lift with 35's
traction bars
4" MBRP turbo back straight piped to 6" single stack
some other pullin goodies
Kyle
Anybody can make biodiesel. The process is not very hard to do. The question is weather the bio is quality bio or not.......... I, for one would not use bio from a source I did not know. How does this "guy" make his biodiesel, does he wash his bio, has he done any quality testing, etc? Bio will feel a little "thicker" than #2, and can be colorless or darker, depending on if it was made with virgin oil, or heavily used oil.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I am not sure of the process he uses, but he said he has been running it in his 99 7.3 for the past three years without a single problem. The bio is like a gold color, not cloudy or dark, and it seems like there is no water in it. I just wanted to try some in my truck before I go and buy everything to make my own processor. I am definitly going to start putting a processor together now.
Kyle
__________________
04 crew cab 6.0 4x4
train horns
remote start
5" lift with 35's
traction bars
Some guys suggest weighing a sample of the bio, bringing the temp up to 212, then weighing again and subtracting the post heated oil from the first sample weight to check for water. The 3/27 test on infopop is an easy way to test and see how well his process converted the oil.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
An easy test for water is simply putting some of the bio in question in a pan and heat it above 212 deg and watch for "spitting" or bubbling. Good "waterless" bio SHOULD NOT show any signs at all untill you reach 350+ deg. If it where me, I would try and talk to this "guy" and find out just how he makes his bio.
__________________
Do you think it is bad for my fuel pump to be running this stuff if it is a little thicker than regular #2. Also, I will do the test Fabman talked about and see what happens. Thanks
Kyle
__________________
04 crew cab 6.0 4x4
train horns
remote start
5" lift with 35's
traction bars
Also, when I put half a tank of Bio in my truck and half a tank of #2, will it blend or does it have to be heated to actually blend. Would the bio just go to the bottom of the tank since it is heavier? Thanks
Kyle
__________________
04 crew cab 6.0 4x4
train horns
remote start
5" lift with 35's
traction bars
