Rear windows on a panel 53-56
Received 4,135 Likes
on
As mentioned in a previous post I made a big rear window on the one piece hatch door. Now I'm wondering about the rubber window molding. What have those who have done this mod used for window molding, it is different than what is used on a pickups rear window so not sure if it would work, I thought if I bought the originals (pair) I could cut and glue but not sure if I'd get good results, Suggestions???
John
John
You can buy window seal in rolls that you cut to size. JC Whitney sells it:
http://www.jcwhitney.com/autoparts/P...window+channel
Or you contact a place that sells supplies for industrial equipment. I installed a lot of windows in big trucks and heavy equipment using this kind of material when I worked in a truck body shop. Also, contact your local class shop and tell them what you need, you're going to have to go to them to have the glass cut anyways.
on
