I Went to Look @ The F100 Today
Over at Dave's. The only body work it needs is on some rot down low in front of the driver's door, and a couple of little screw holes. The motor sounds tight, but will need to be cleaned up and have the oil pan, valve cover & front cover gaskets replaced. There is a coating (for lack of a better term) on the roof - I don't know if it was a vinyl top or not - but it could use some attention. Windshield and rear window rubber could stand replacement as could the weatherstrip ,window channels and cat whiskers. The grill can, I believe, be straightened, and a couple of the trim moldings could stand to be replaced.
Wiring in the engine compartment - maybe a harness for the charging system from the junkyard. It has the carter spark-retard smog bs that can probably be 86'ed along with the dual vacuum advance for the distributor.The carb could stand a rebuild.
The interior will take some work as well - (2) door panels, upholstery, etc....
All in all, it's a project that requires more time than money - which is a good thing.
Here you go, Bill - numbers!
F10GRF37829
WB COLOR BODY AXLE TRANS
131....U.......1......81.......F
AXLE GVW HP RPM DSO
09 5000 152 4000 51
I'm interested in the District Special Order #51 - trans and axle possibly?
F10GRF37829
AXLE GVW HP RPM DSO
09 5000 152 4000 51
Originally Posted by Col Flashman
Steve
Please don't you do what other FTE'rs have done here in the past & Not type Out What Year truck you are writing about.
You know that the F-100 designation covers from like '52 to well into the '70s. Please, throw us a Bone here.
This is Dave's post from the "group project truck" about this truck:
Guys,
We have a '69 F100 our family wouldnt mind turning into a chapter group project. My fiancee and her mother will even keep it registered and insured. It was my fiancee's father's truck when he passed away almost 2 years ago. He wanted to fix up the truck, but never found the time and was running into health problems. The previous owner before him was my fiancee's uncle, who passed away and left it to my fiancee's father. I put wooden siding on it to take a couple of loads of trash to the dump which i plan to remove in the future. I had dreams of stuffing the biggest motor possible in it, maybe a 4x4 conversion or just making it a nice slick boulevard cruiser. Its just sitting here in the driveway waiting for attention. Its up to you guys
Originally Posted by SteveBricks
F10GRF37829 131 U 181 F 09 5000 152 4000 51
G = 302 2V
R = San Jose Assembly Plant
F37829 = 1969
131 = 131" Wheelbase
U = Gulfstream Aqua
181: 1 = Dark Blue Corinthian Vinyl & Dark Blue Shetland Check Cloth / 81 = 81B Custom Cab
F = Warner T-18 4 Speed Transmission
09 = Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
5000 = 5,000 lbs. Gross Vehicle Weight Rating
152 HP @ 4,000 RPM
51: Denver, Colorado Ford DISTRICT SALES (Zone) OFFICE - where the original selling dealer ordered the truck from.
It's not a Domestic Special Order. If it was, the DSO would be six digits.
btw: The dog dish hub caps are 1977/96: D7TZ-1130-A
This is a painted on ~ (made to look like a real) vinyl roof.
Very common once, tho I've never seen one on a truck of this vintage...cars were the usual victims of this charade.
Believe it, or not...this is a Gen-U-Ine Ford Dealer Installed Accessory
It took a bit of lookin', but here's the Ford part number > >
C7AZ-19500-Z .. Wrinkle Roof Paint-Black-1 quart can
Originally Posted by Nighteyez
Didn't say anything about the in dash AM/FM/8-track/CB radio tho.
Besides, that type of radio wasn't availabe from Ford, ever.
1969's had a in dash optional AM radio, a hang on stereo was also an option. That's it.
Wow Bill you are amazing! I uploaded a whole bunch of pics in my gallery if anyone wants to see. As of now we arent certain what we want to do with the truck. We have so many vehicles around here. If everyone chooses to make this the project truck, does anyone have a place better than mine where we could work on it and park it?
https://www.ford-trucks.com/user_gal...&albumid=33279
