Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
coolent leak on 93 lightning
Old 03-08-2008, 05:13 PM
bucs250's Avatar
bucs250
bucs250 is offline
Just bought this truck last week from a old man, everything bone stock, 49000 original miles. got home today and noticed coolant dripping from where oil plug is. got a mirror and saw coolant pooled up behind motor on top of bell housing
any suggestions or is it a head gasket. Does coolant flow thru intake at all?
thanks chris
Old 03-09-2008, 12:11 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Check the EGR coolant line that goes from the lower intake into the EGR spacer. There is another line that goes from the spacer to the radiator filler neck......check/replace those lines first.
And yes, coolant does flow through the lower intake on those rigs. If the EGR lines are good, I'd go there next. You can also do a leakdown test to see if the head gaskets have failed.
Old 03-09-2008, 07:50 AM
bucs250's Avatar
bucs250
bucs250 is offline
thanks for info, any easier way to see behind motor besides mirror on extension and flashlight. Obviously taking upper intake off is easier but want ot diagnose before taking off. If I take drivers side wheelwell plastic and tire off can I see better up there?
Thnks
Old 03-09-2008, 10:10 AM
bucs250's Avatar
bucs250
bucs250 is offline
looks like it was hose from lower intake into egr, brittle tiny pinhole, pain to get off, should i replace the fitting on top of lower intake or just leave it alone
thanks
Old 03-09-2008, 10:13 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
If it's layered with heavy rust or heavy corrosion (I don't remember what material the stock piece is made of), I'd say it's probably fine.
sgrol
6.7L Power Stroke Diesel
09-30-2014 07:54 AM
johnf2507.3L
08-11-2013 12:16 PM
ilcowman
06-14-2011 08:01 PM
Flytyer
1983 - 2012 Ranger & B-Series
05-17-2011 11:19 AM
tuke
10-09-2006 11:09 PM
Quick Reply: coolent leak on 93 lightning
