Carb choke linkage - broken, where to get
I have a '72 390 2bbl motorcraft carb and the white plastic linkage between the choke and the throttle is broken. I think it controls the increase in throttle when the choke is closed/cold. Is this part replacable? The local Napa says no...
I hope that explains the part - here is a picture pre-break:
The part is located between the choke and the carb body on the passengers side - it attaches to the back of the choke and links up to the throttle contol, and has a small hex screw sticking out of the top of it. I'ts hard to see in this picture, but you can see it if you know what I am talking about.
Thanks guys - Mi1ion haven't been on the site for a few weeks and you know how fast the topics rollover. Fast Idle Arm...good to know the name of the part. I will check the HELP parts because I want a new part if possible. I'm surprised it's not a part that is sold anymore, of course nothing surprises me with a truck thats older than I am. Thanks again guys.
D5AZ-9597-A .. Fast Idle Cam (Motorcraft CM-2015)
Fits: All Ford 2V carbs 1971/79 EXCEPT the Variable Venturi 2V carbs used on some 1977/79's.
MikeWire
26
02-07-2014 11:25 AM
MikeWire
09-10-2007 05:39 PM
MikeWire
05-21-2007 11:27 AM
