How good is the Desktop Dyno's vs the real thing .
Old 01-29-2002, 07:35 AM
shazam's Avatar
shazam
shazam is offline
OK has anyone out there had the Opportunity to put a real dyno'ed engine on the Desktop Dyno to see just how close they really are.
I did a few years ago with my buddies 521 that dyno'ed out at 828 H.P.
and on the desktop it came out to 821 H.P. So I have always felt the numbers I get from my desktop dyno would be within reason give or take a few H.P.'s.
Old 01-29-2002, 12:49 PM
400m's Avatar
400m
400m is offline
I was skeptical about it and used it the other night my motor dynoed at 380hp and I used the program and it came out to 370 but that did not account for some added machining and porting on my motor so I seams to be pretty accurate.
400m
Old 01-29-2002, 09:10 PM
shazam's Avatar
shazam
shazam is offline
So then are you happy with your motor and the way it turned out? Had you ever wished you had played with it on the DeskTop Dyno before hand, and if you did would you have build it any differant...
Old 01-31-2002, 12:01 PM
400m's Avatar
400m
400m is offline
I did wish I had it before hand, but I did spend some time playing around with it. I did find for the type of driving off-roading and towing especially in the mountains my current engine choices were right on. but I no longer live in the mountains and the truck does not venture off road anymore so some changes may be in order. I am going to use it for my BroncoII build up.
400m
Old 01-31-2002, 05:44 PM
fatdaddy's Avatar
fatdaddy
fatdaddy is offline
Where can I obtain a copy of this computer program----and does it run on windows 98???????????fd:-X11
Old 01-31-2002, 06:27 PM
Bill_Beyer's Avatar
Bill_Beyer
Bill_Beyer is offline
[link:shop.store.yahoo.com/gofast/desdyn20orde.html|Yahoo Shopping]
Yes it runs on Win98. I have it and it works well.
Old 01-31-2002, 06:30 PM
Fastcat's Avatar
Fastcat
Fastcat is offline
Here ya go!
http://store.yahoo.com/autoaccessory/desktopsoftwarefl.html
Old 01-31-2002, 08:36 PM
shazam's Avatar
shazam
shazam is offline
Also can find it in Jeg's Catalog and I got mine at the parts store, "Checker Auto"
Old 02-01-2002, 12:04 AM
Big Blue4x4's Avatar
Big Blue4x4
Big Blue4x4 is offline
Is the program worth the $40 ?
Wanted: Winch for pulling out Chevys!
79 F150 4x4 410m built!(9.1:1,KB pistons,custom Comp Cams X-Treme 210/218-.508/.524,roller rockers)/c6/3.5:1 gears,4.11:1 soon, Demon 4bbl, 285/75R16 BFG Mudders on alumn. mags with New Drk. Blue paint.
65 Ranchero 170-6, 3on the tree, solid mags, New Bright Yellow paint
Old 02-01-2002, 10:41 AM
shazam's Avatar
shazam
shazam is offline
If you are into building motors and want to try differant combo's yes it's worth every penny ..
Old 02-14-2002, 12:36 PM
GT40man's Avatar
GT40man
GT40man is offline
i got the cam disk, and that really makes it easy to try different cams.
Old 02-15-2002, 07:32 AM
dzjammer's Avatar
dzjammer
dzjammer is offline
Just want to add that Dyno2000 only displays 2000 RPM and up. The older versions show results from idle.
Old 02-15-2002, 09:32 PM
shazam's Avatar
shazam
shazam is offline
OK so just what can you do with your motor other then Idle under 2000 RPM's.Under normal driving your motor turns 1500 to 2000 RPM's or better to get you moving and cruising is usally at 2250 RPM's or better at 55 MPH, Depending on what gears you have.
Old 02-16-2002, 02:48 AM
GT40man's Avatar
GT40man
GT40man is offline
so what heads do you chose for cleveland 4v heads with 2.25 valves?
Old 02-16-2002, 01:30 PM
shazam's Avatar
shazam
shazam is offline
[updated:LAST EDITED ON 16-Feb-02 AT 02:57 PM (EST)]I used the Large valve pro ported heads for this motor ..
And for Clevland heads you use the Canted valve heads ..
Quick Reply: How good is the Desktop Dyno's vs the real thing .
