Buildup!! 06 crown vic front suspension into 67 F100
Old 12-10-2009, 10:08 PM
carcrafter22's Avatar
carcrafter22
carcrafter22 is offline
Good job, I should get it. I'm working on adapters right now to get rid of the isuzu flywheel housing and be able to bolt up a ford, chevy or dodge tranny.
  #1007
Old 12-11-2009, 08:15 AM
Rusty 63's Avatar
Rusty 63
Rusty 63 is offline
aaargh! He listed it the 9th, sold the 10th! Missed it. Wonder if he realized he was giving it away?
  #1008
Old 12-11-2009, 08:48 AM
carcrafter22
Its ok, I have seen them go for $800 for the entire truck before. I just picked up a motor for $300 complete with trans
  #1009
Old 12-11-2009, 09:46 AM
Rusty 63's Avatar
Rusty 63
Rusty 63 is offline
Cool. I'll try to keep my eyes (and engine bay) open!
  #1010
Old 12-14-2009, 05:48 PM
Andys60F100's Avatar
Andys60F100
Andys60F100 is offline
Lift block CV front end
Carcrafter your thread has inspired me to do the CV swap for my 60 F100. I was able to get an 03 front end for $225. I got mine by looking for the rear end for a CV because my search for a "engine cradle" ended with 0 in my NJ area. So I called about the rear and asked if he had the front end. I had the guy cut the frame right below the firewall. I am using the original hardware, and structural tubing for the cradle. The frame on the 60 is not flat on the bottom, so I am welding 3/8 flatbar on the bottom to even the frame out. This CV swap is not going to give me 5" drop as with the 67. I am going to end up with about 2" of drop because of the 50 year old springs ( sagged ) on the straight axle and the frame configuration. This will be great! Thanks for your help. Sorry if this not in the right place-- I'm the new guy (first posting)
  #1011
Old 12-15-2009, 06:05 AM
Andys60F100
CV IFS Swap 60 F100
New Guy here, The frame on the 60 is not flat on the bottom as is the 67 frame. My idea was to install a piece of flat bar ( 3/8 X 2 1/2 X 14 ) to the bottom of the frame and cut the frame where it begins to slope and weld it in place. Then drill the frame for centering pin and bolts. Then install my factory support "pipes" trimmed to size then box the frame. Attached is photo and my sketch of the proposed work. I am open to suggestions and or advise. Thanks for all the help so far on this thread. Andy
  #1012
Old 12-15-2009, 11:37 AM
72-F100-4V's Avatar
72-F100-4V
72-F100-4V is offline
that sounds like the correct approach. Cant wait for the build pics!!
  #1013
Old 12-16-2009, 12:55 AM
SanFORDf100's Avatar
SanFORDf100
SanFORDf100 is offline
Just wanted to say that I have been following this thread since day one, and it has inspired me to change directions on my 70'. I'm chucking the (dare I say it, they were free) Chevy parts and may have scored an 03' CV p-71 for $165.00! I don't think i'll flood the board with another buildup thread, but i'll put some pic's on my profile. Thanks for all the tips, tricks, ideas! Love how nice your truck is coming out!
  #1014
Old 12-16-2009, 02:59 PM
carcrafter22
Sounds like your doing it the right way Andy, and much safer than some ideas I've seen.
Thanks sanFord, hope you get it going soon.
  #1015
Old 12-16-2009, 04:57 PM
Shoestring's Avatar
Shoestring
Shoestring is offline
Andy I like the look! Love the rims too, what are they from or did you order an aftermarket rim? I have some friends that are looking to put this on the older model trucks and I will also be interested to see your progress.
SS
  #1016
Old 12-16-2009, 06:02 PM
Andys60F100
SS The wheels are stock 02 Mustang Bullit wheels 17X8's ( $350 set on craigs list) with my own custom touch to the center cap. Tires are 235 55 front 275 60 out back. I used a billet 2 inch spacer adapter in the rear to get the 5X4.5 bolt pattern. 9 inch rear is staying out back - 408 stroker with dual quads going in out front. I plan on lowering the back to make the truck sit level after the CV IFS. I just updated some pictures and add my garage to FTE. Thanks Andy
  #1017
Old 12-17-2009, 04:42 PM
Shoestring's Avatar
Shoestring
http://i985.photobucket.com/albums/a...y_25_09006.jpg
Looks great, stance already looks pretty good. I do like the looks of the 5 spoke rims. I am looking for 18s i think to put more of the rubber under the fender wells. What rim backspacing did you have to get for the front and is it different from the rear?
  #1018
Old 12-17-2009, 08:40 PM
Andys60F100
Post
ss the wheels are stock Ford Mustang I think the offset is 35 mm and the backspacing is about 6 inches. They fit untouched on the front of the CV IFS- bringing the tires to the edge of the fender like I wanted. I am using the original 9inch rear, These wheels would not work without the 2 inch billet spacer with pattern change 5X5.5 to 5X4.5 this puts the tires also to the edge of the wheel opening like I wanted. Thanks Andy
  #1019
Old 12-18-2009, 10:19 AM
Shoestring's Avatar
Shoestring
Man that is good to know, so the rear and front have the same back spacing but with the 2 inch spacer it brought both front and rear even. I am also using the original rear end, mine unlike yours is a Dana 44 with trac lock.
SS
  #1020
Old 12-23-2009, 04:12 AM
townlow's Avatar
townlow
townlow is offline
Hello, new to the site. I am located in Phx, Az. and have been following this forum for awhile. I don't recall if it was mentioned, but the 2003+ Lincoln Town Cars have the same front suspension setup, but a couple more pieces are aluminum. (lower control arms, upper brace, etc.) I actually have a 2003 Town Car that I bagged and made a new cradle from scratch out of metal and bolted it in like the original cradle was. I did this to get lower and to narrow the track width so I could clear my fenders with the wheels.
I HAVE A 2003 CROWN VIC AVAILABLE IF ANYONE IS INTERESTED. IT IS STILL IN THE VEHICLE AT THIS TIME. THE REAR AXLE IS AVAILABLE AS WELL. I also have JUST an aluminum cradle and front sway bar left over from my car. make offer... thanks.
Great build by the way, VERY informative.
Quick Reply: Buildup!! 06 crown vic front suspension into 67 F100
