Nebraska Chapter Join Chapter, Leader: 97nukeford
4.0 SOHC to 4.0 OHV can it be done
Old 03-01-2008, 02:14 PM
fordnut forever's Avatar
fordnut forever
fordnut forever is offline
have a 99 exploder w/4.0 sohc and its locked up, i have a 4.0 ohv out of a 99 ranger, can it be done? any of you ford mechanics know?
Old 03-06-2008, 11:05 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Redneck-Cowboy is offline
Switch the engine? Hmmm, I was comparing the SOHC belhousing to a 3.0L the other day (SOHC/Explorer and 3.0L/Ranger) that we had sitting on the floor, well the bolt patterns were different on the back of the blocks, now I'm not sure if the pushrod 4.0 matches the 3.0 or the SOHC, maybe the SOHC matches the 5.0. I know none of that was helpful, but I love the idea of you taking another SOHC motor to the junkyard and putting another 4.0 pushrod on the road instead, lol. I'll do some checking at work tomorrow and see what I can find out. If nothing else you have to change all your wiring and pcm over, now some of the tranny wiring is also in that harness, if your ranger had an auto in it, I'd just throw it all in and be done, that would eliminate your engine bolting up problems. When I was lookin at the SOHC and 3.0L the other day I had commented to the other tech that ford still didn't learn, JUST USE ONE OR TWO BOLT PATTERNS!!! That is the one thing that put chevy ahead in the performance world, there are a lot of motivated ppl, those are the ppl that put a 454 where a 350 was, then there's the super motivated ppl, well...... they do engine swapping in Fords.
Old 03-08-2008, 05:27 AM
fordnut forever
tranny in the ranger is a manual 5 sp, and auto in the exploder,lol so that might be my downfall,bolt pattern looks the same [ so says my helper] seems the 3.0 is in a class all by its self, had a guy wanting the tranny out of ranger but his motor was a 3.0 so it won't bolt up,anyway thanks for the reply
Old 03-08-2008, 07:46 AM
Redneck-Cowboy
Well maybe the 3.0L fits with the 2.3L and 2.5L 4cyl's, it should also fit the 3.0L DOHC since they used both in Tauras's.
Michaelj615
Bronco II
05-02-2019 12:22 PM
mdelfunt
1983 - 2012 Ranger & B-Series
06-28-2017 06:30 PM
mdelfunt
06-26-2017 11:12 AM
BTclassics
03-03-2017 07:19 PM
Frozen_Joker
12-05-2015 11:36 PM
Quick Reply: 4.0 SOHC to 4.0 OHV can it be done
