Doved Front End
Originally Posted by MBBFord
Sounds like you got a big jump on it, good work!
It'll be all worth it when your done so Get R Done.
i still dont have my camera, will get pics soon!
-cutts-
Really hacked out a chunk of that grille. Nice work.
After you do a few adjustments you should be able to start on the hydro system pretty soon.
Did you cut the hood yet, and how are you going to latch it down(or open it for that matter...hinges, hood pins, original hood latch)..... just curious?
no i have not hacked up the hood yet. i will prolly use the original hinges but i have been using hood pins for a while. just have to fab up a spot to put them. i will continue my steering build as soon as i can. i think the trickiest part will be mounting the ram. i am not 100% how I will do it just yet considering how little room i have on the driver side!
anyone has any advice on trimming the hood to fit, please pipe up!
-cutts-
-cutts-
cutts, take the measurement from what you took out of the grill. make it the base of a triangle at the front of the hood. then run the sides of the triangle along the hood to a point at the back. cut the triangle out and it should allow you to weld the hood back with the apropriate amount from the front and still leave the back the same distance. i hope this makes sense.
