51 f1 power steering options
#31
Agreed, like dmack91 suggested it would be better if you started out with a new thread.
There are several guys around here who have mounted power steering pumps to the flathead and could probably give you some advice. The power steering box of choice is the 79-85 Toyota 4x4 steering box (from trucks with the solid front axle, the independent front suspension 4x4's are different).
Good luck
Bobby
Good luck
Bobby
#32
Hi, I plan to also put power steering on my 50 Ford F1. No one has clearly shown me how to install the pump and where it would drive from. I have a plan that no one has even suggested. Press out the shaft that holds the fan and have a pulley built that will fit next to the pulley that drives the fan. I won 't know if it will work until I get the engine back on the frame and determine if there will be clear path to where the pump will mount. Still need to find a Toyota steering gear.
#33
#34
Hey guys
I am planning to add p/s to my f1 and was wondering what my options are out there, and what others have used with original straight axles. I have seen kits using a toyota gear box for the f-100s but nothing for an f-1. I also have seen a power assist set up attaching to the tie rod. I like the toyota set up a little better, any ideas would be appreciated. thanks Matt
#35
A good place to "look" for a used Toyota steering box is to search out clubs or groups that do a lot of offroading and/or rock climbing. The early Toy 4x4 truck is very popular, but when heavily lifted the original gearbox doesn't work, so they pull them out and replace it with the newer style box. Many have the old box under a bench on a shelf, or thrown in a corner, and are glad to get rid of it. Don't be afraid of going with a used box, there are near bulletproof. In fact most of the ones sold as "rebuilt" just have the external shaft seals replaced, painted and tested, or quite often are just painted.
#36
When I installed my Toyota Steering Box I went with a Manual Toyota unit, sense I didn't want to try to install a pump on the Flat 6. There were some guys on here years ago talking about an Electric Pump possibly being used. But I'm perfectly happy with my manual unit, besides nothing else is power on the truck anyhow....
#37
I have just finished the Toyota box conversion on my 55. If the box and various dimensions are the same on your 51 I intend to post a pictorial and article on the complete project.
A quick answer to your question about the original column....it was no hassle at all but I think I can offer you some info to avoid the surprises I had.
#38
#40
#41
toyota steering box
I'll pay $150 and add another $30 for shipping to 76513 (central texas). My e-mail is robtn195@aol.com--thanks
#42
I was able to find a 1953 Ford pump on eBay but it was missing the bracket connecting it to the block. Couldn't find one unless I wanted to pay a high price for an entire kit which I did not need. So after designing a three piece bracket using Google's free Sketchup CAD program today we made the brackets using a plasma cutter. They are fascinating to watch as it cuts through 3/16" plate steel with no effort. It took longer to create the CAD drawings and set up the plasma cutter than it did for the machine to cut them out. The most complicated one only took just over 1.5 minutes. Here is the video:
CAD drawing
Finished parts sandblasted and ready for chrome powder coating
Anybody need me to make another set?
CAD drawing
#44
The chrome finish looks a lot better than the picture shows.
