Roller Rocker question?
I have some extra Crane 1.7 rockers from a windsor. I haven't removed the valve covers on my Bronco or done too much research on it's 400. I think remember the person I bought it from saying that it has pedastal mount rockers. Can I use these on my 400? It is a new stock 400 and the heads were shaved alittle and it has a Performer cam. What kind of piston to valve clearance am I looking at? Whats the max cam lift and duration for a stock 400? I thank you in advance for any help.
The rockers for a 400 fit 351C,351M,429,460. The ratio for these rockers is 1.73:1. The geometry is wrong for a windsor type rocker. Do you have the part number for the rockers you have? If so you could call Crane. A 400 head can be machined to accept studs and pushrod guides to use Big Block Chevy roller rockers. There are a variety of other ways to install roller rockers on a 351C/M,400 or 385 series also.
