Gear position indicator (PRNDL) wont go into park "selector misaligned?"
Just now my gear selector P R N D L wont go into park, it seems like it " moved to the right " since now park is actually on Reverse and so on,
seems to me the the little arrow has shift some how,
How do i fix this ?
How do i fix this ?
I just looked at the cable, but mine simply comes in throught the floor in a rubber sleeve, gets held inplace near the brake pedal with a plastic suport, and then straight to a metal braket with a zip tie holding it there (it goes through a small plastic ball wich is held to the metal suport) , and then to the actual shifter behind the dash!
The cable is solid (there are no unions) any place.
Do you mean the part of the shifter wich the cable ataches to?
theres got to be a fix for this, all gears work....it just that damn red arow ....
I am not sure what year your vehicle is, but usually there is a little string like cable that moves the indicator. The clip may have slipped, or the little cable broke. The ones I am familiar with, you have to pull out the instrument panel to access it. Again, I don't know if yours is set up this way. Cheers..
