Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 02-18-2008, 10:31 PM
william_04_x's Avatar
william_04_x william_04_x is offline
Garage is empty, add now
william_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant futurewilliam_04_x has a brilliant future
6.0l Excursion SEIC(high idle) mod
After looking around for a long while, and not really finding a really good post on this mod, I got around to giving it a try..
With a wiring diagram manual for my 04 X(and SD trucks) I had the confidence to go forward with this..My truck is an 04 with 03 engine..I don't know if this works on 05's..If you fry something don't come crying to me..
The manual showed the pin position on the PCM for the +12vt signal input..Just as i've read in the past, there was no wire in the harness or PCM connector for the input..I had to make one myself...
I pulled the driver's battery connections and cover..The SEIC input is in the rearmost PCM connector..The back of the connector will pry off easily with a slotted screwdriver after it's pulled from the PCM..Work it at each corner..
I used a small red spade connector to make the wire to PCM pin connection..I cut off the red insulation and gently crushed the round wire recepticle to make it a little oval shaped...The pin you are connecting to is rectangular..Then I trimmed the spade portion of the connector to match the width of the recepticle end...After that i soldered a small 20GA pigtail onto what was left of the spade of the connector...It isn't pretty, but it fits into the PCM connector and mates nicely with the pin in the PCM..
Now I had to get my makeshift pigtail into the connector...I used a small drill bit to go all the way through the connector and fish the pigtail out the back..Be carefull not to hit the other wires when drilling through..
Here's a good pic of the back of the harness for the pin location..The new wire is the blue one..
After I got it all in there I plugged back into the PCM and gave it a test by starting the truck..The first key cycle, no starter..Tried a second time and it started right up...I guess it was because of disconnecting the batteries..I tested by touching the pigtail to the + side of the battery...Engine rolled right up to 1200 rpm's just as I hoped..
Since it was working, I put a little glue in the hole I drilled into the connector for the wire..
control is from the dash from a new switch (plus a couple for future mods)
all works just fine....
  #2 (permalink)
Old 02-18-2008, 10:41 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a very good reputation on FTE.mudmaker has a very good reputation on FTE.mudmaker has a very good reputation on FTE.
Where did you get those switches? They are very clean looking. Nice write up on the high idle.
__________________
Marc
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip
2001 F250 4x4 PSD, SUPERCAB, ARE UTILITY TOPPER
  #3 (permalink)
Old 02-19-2008, 10:38 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
You are the man dude. I have wanted to do this mod for some time and that is the instructions I have been looking for. Rep points for you.
__________________
Nick PAA#9
08 F-450 KR 6.4 Elite Race Trans, Elite 71mm turbo, ARP, RDP I/C Boots, 5.5 Icon lift, 22.5 AF Independence wheels, OUO
04 X 6.0 Powermax, ARP studs, MBRP, RDP I/C boots, SCT with Inovative, 14.0@96.4MPH
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots *** Big Thanks To RiffRaff Diesel Performance ***
  #4 (permalink)
Old 02-19-2008, 04:41 PM
Magilla_v6.0 Magilla_v6.0 is offline
2004 Ford Excursion
Magilla_v6.0 is starting off with a positive reputation.
Very nice! That is on my list of things to do to my X.
  #5 (permalink)
Old 02-19-2008, 08:24 PM
glad you guys like it...i never found a good post on this in the past 3 years..it's really not that hard to do...just takes some guts to throw 12vt at your PCM where it wasn't before...the switches are off the shelf from the local auto parts store..have fun with it..
  #6 (permalink)
Old 01-03-2010, 12:57 AM
UPDATE to add pics back that have disappeared from my original post.. I've since found that this works fine on 05's
Now I had to get my makeshift pigtail into the connector...I used a small drill bit to go all the way through the connector and fish the pigtail out the back..Be careful not to hit the other wires when drilling through..
  #7 (permalink)
Old 01-03-2010, 12:42 PM
Master of Strokes
2004 Ford Excursion
My Garage
Hey Willam are you going to made it down to the Phoenix race this year?
__________________
Nick PAA#9
  #8 (permalink)
Old 01-03-2010, 12:54 PM
BigRy's Avatar
BigRy BigRy is offline
BigRy is starting off with a positive reputation.
Why is this different than the regular F250 Diesels and the Excursions?
__________________
________
Ryan
05 Limited 6.0 Excursion
Don't you just love the smell of diesel in the morning......
  #9 (permalink)
Old 01-03-2010, 09:55 PM
Quote:
What Phoenix race?
Quote:
6.0l Excursions don't have the signal wire in the cab to PCM harness..
Ford has different wiring harness' in X's (vs Super Duty trucks), as X's don't have PTO options.. Without a PTO they saw no necessity for the SEIC PCM signal wire, so that's how they were built..
  #10 (permalink)
Old 01-04-2010, 07:05 AM
katiesdad7 katiesdad7 is offline
katiesdad7 is gaining momentum as a positive member of FTE.
It was cold this morning when I started the Ex. 38 degrees. I stated it and went back inot the house. After about 3-4 minutes I went back outside and the ex was idling fast. The tach showed about 1k rpm. When I put the brake on to switch to drive the idle went back to normal.
__________________
2005 Eddie Bauer 4x4 w/6.0 PowerSlot Cryo Rotors up front, Hawk LTS pads all around, Bi-Xenon HID's.
Who said size doesn't matter?
  #11 (permalink)
Old 01-04-2010, 07:40 AM
BigRy's Avatar
Same here in Tampa, it was 35* and I have a remote start when I came back out to the window heard the truck idling high. I know that the PCM adjusts the idle based on enviromental temps also.
William, Are you sure its different for our Excursions, I located both wires for the high idle mod under the dash of my excursion, I just havent done the High Idle Mod, because I am waiting to install my F650 dash panel.
__________________
________
Ryan
  #12 (permalink)
Old 01-04-2010, 08:22 AM
JaySVX's Avatar
JaySVX JaySVX is offline
2004 Ford Excursion
JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.
That's called warm-up idle. Any/every car/truck/suv in the past 10-20 years will do that. The high-idle mod puts it at about 1200rpm, and won't take 3 minutes of sitting idle in park to kick in.
Those are the same switches I got for mine. I got mine from radio-shack though. I like the different color lights, as mine are all red.
__________________
2004 Ford Excursion 6.0
2001 Yamaha Roadstar 1600
1989 Porsche 944 w/400hp LS1
Quote:
Originally Posted by ncheavymetal View Post
But I have an excursion and don't concern myself with matters such as "how much does it weigh?"
  #13 (permalink)
Old 01-04-2010, 11:31 AM
jdw1 jdw1 is offline
jdw1 is gaining momentum as a positive member of FTE.
Thanks William 04 X
looks like if a guy had weatherpack it would be good to go. Am I to assume that the blue wire in your pictures was installed by you and not a OEM wire?
One more thing where did you get those switches?
Thanks
__________________
2005 X 6.0 Limited 4x4 (Hers)
2002 F-350 7.3 XLT CC LB 4x4 (Mine)
2000 X 7.3 XLT 4x4 (Ours)
  #14 (permalink)
Old 01-04-2010, 08:11 PM
If you already have the wires, consider yourself lucky.. Maybe they threw in a SD harness.. After 5 years of reading about 6.0 X's, yours would be the first I've heard of with the wires from the factory.. Do you have really late build date?
  #15 (permalink)
Old 01-04-2010, 09:07 PM
Master of Strokes
2004 Ford Excursion
My Garage
What Phoenix race?
I thought there was a NHRDA race soon down there. Duckfan and I were going to go down there?
__________________
Nick PAA#9
Tags
04, 2004, 60, 60l, excursion, ford, high, idle, idling, make, manual, mod, mods, seic, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
