fluid check
fluid check
I have a 04 f150.w/62000 miles,time to change all fluids.i know the diffs. have syntenic oil . I like to keep things clean,anyway I started with frt/diff. pulled the plate off out comes this milkey gray stuff. unless frd/has a new oil? gears looked ok.changed w/mobil.2qts-next transfer case. took off filler plug to see leval.out comes this stream of oil!! calls for two qts. had to be at least 3! drained an filled ..next r/diff. opened filler plug finger test no oil.had 1 qrt of mobil left.to top of ,well it took 1 an a half qts.no leaks!!but the thing that ! me the trk/was running find....
I had the same thing with my transfer case, 1-1 1/2 qts overfilled. Someone said that a seal between trans. and transfer case was leaking but I don't see that as my trans never had to have any fluid added. If there was "cross leaking" then I would have had to add a qt. of ATF to the trans. which I have never had to do. As for the rear end I also had a problem with the low fluid level. Mine turned out to be an axle seal but it didn't show as a leak because it stayed(for a while) in the ebrake drum.
I ask because you said u had 1 qt left when you got the the rear diff, after the front and T-case
