p.o.s
The fella that started my truck got killed in an auto accident. His wife kept the truck in the shop for about 5 years and finally decided to sell it. I had told her about 3 years earlier that if she ever sold it to let me get the first shot. She did and I bought it. Still needs a lot of work but I am plugging along and hope to have it on the road by spring or early summer. Not done but on the road. It is not a show truck.
What the PO's did huh? Hmmm, where to start??
Let see, there were the large bolts in place of the rear spring shackle pins. the only thing keeping them from falling out were the lower bedsides....
Then there was the home made dual exhaust on my flat 6, the PO bored a hole in the exhaust manifold and "welded" (notice the quotation marks? thats because I use the term welded very loosely here....) a chunk of pipe in that connected, through flex pipe to some glass packs under the truck
Of course there was the obligatory radio hole in the dash that was cut in with a combination smoke wrench and church key....
The fuel tank was removed from the cab. It was setting in the bed of the truck with a piece of 1/8 plate welded behind it to protect it. the remaining piece of 1/8 plate was used as a bed floor.
2 pieces of 1" square stock were welded to the bedsides, vertically at each wheel well (presumable to add stength????)
The rear stake pockets on the truck had been smashed flat and large pieces of 1/4" diamond late welded to them to hold up some tailights that looked like they were stolen from a travel trailer
The seating was fully custom and consisted of 2 bucket seats on fishing boat pedestals (yup, they could pivot 360 degrees if you had the room)
Custom wiring harness using all one color wire(red)
....and lets not forget....**** carpeting
Bobby
Bobby
on
Hmmm, this post isn't what I thought it would be. The title should have been P.O.'s not P.O.S. which means something entirely different...
But, since it is about previous owners and not pieces of #### (which oftimes amount to the same thing) I must add my own rant. I spent several hours separating the seat frame from the floor in my F-3 because the PO welded it to the floor. I suppose he thought no one would ever want to remove the seat.
Mine had a 283 dropped in it and aluminum slots. The P.O. moved to AZ from IO and left it in his Moms barn.
He came home about 10 years later to stay and it had to be one of his friends but his tranny was stolen.
He wanted to fix it up but it was just too much.
I found it for $500
It had been green originally and was painted red (faded to orange) with primer brown interior, dash and all was painted brown.
I found it for $500
Where to start, there's just so many things...
Lots of black electrical adhesive tape wrapped around wires that are twisted together, sometimes with wire nuts for house wiring. I replaced the wire harness to fix that problem until I recently found that the headlights were wired that way too. Always wondered why the headlights were so dim.
I bought my truck as a "driver". It had some obvious cosmetic problems and the driveline was really tired, but I was inclined to think it was basically sound since the PO built it for his daughter as her first car. She had driven it for 8 years.
He said it had "a vibration" at 60 mph. I found out what the vibration was driving it home when the driveshaft fell out on the freeway.
And so the saga began...
A buddy of mine was building my 51,he suffered a lite stroke, lost some ability in his arm and lost interest soooooo it begins, remove from s10 frame, return to 51 frame,thinking 18 months for driver, 51/2 years later, it is drivable but still in progress,HOW SWEET IT IS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
https://www.ford-trucks.com/user_gal...id=175196&.jpg[/img]
This is our truck as we bought it in 1988. 2x6's for running boards, homemade wooden tailgate with barndoor hinges, it also had a wooden glovebox door and vinyl glued over the dash. Boy it was purdy.LOL
brian...
brian...
i bought my '49 from a friend in 1977 for $200. he bought it for $100 and had some work done on it so he could drive it. the fuel pump failed and he didn't even know where the fuel pump was. he had only a crescent wrench and screwdriver. i, however, had the basic craftsman socket set. i decided i didn't really need to buy a new fuel pump since the existing one was dual action. i just pumped the gas through the wiper part of the fuel pump. it idled great, but the first time i took it on the highway, i had all i could do to turn it around and get home. after a 22 year storage, we are currently redoing most of what i did in the early days. If i want to get PO'ed at the PO, the PO in this case is the Present Owner. dick r.
Robert
