Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 02-12-2008, 02:16 PM
whd507 whd507 is offline
whd507 is starting off with a positive reputation.
I have a 79 F-600 crewcab, and a 76 F-150 that I converted, and I sold a 76 Ranger XLT with deluxe interior crewcab this past year. mine were all rust-free california trucks, but now that they are here in the midwest, I'm anxious to protect them from roof rust. I sprayed inside the seams and hidden spaces before I moved here, with undercoating and/or paint. I replaced the headliners in my F-600 with shiney white board stuff for bathrooms using the remains of the old ones for templates. it is a hair thicker, but the center strip still works. the XLT padded headliners in my F-150 are in bad shape, so I would like to find good ones, or convince someone making repros to make a rear one (its just a different cut of the same stuff).
my 76 F-250 had front shoulder belts, but the cab I used on my stretched F-150 is a 75 cab, so it didnt have anything. I welded in the retractors from the old cab into the rear of the new crewcab, it was pretty easy, and the spotwelds were all in the same spots, even though one cab was a San Jose 76 cab, and one was michigan truck/canada without shoulder belts. that was the back seats, for the front, I found that 78-82 Fairmont WITHOUT the deluxe interior had a self-contained front seat belt that had its own plastic cover that bolted to the flat panel down low, and I made a secure anchor with 3/8 steel plate up where the shoulder anchor goes up top. so I have shoulder belts front and back on that one. I decided to forgo shoulder belts on the F-600 due to slightly rougher ride. the F-500-up trucks had lap belts identical to the 67-72 F-series pickups to match the 68-72 dashboard. on the F-600 I wanted carpet, so I took a pickup floor without the bolt in tranny hump, and made a cover to go over the lower F-600 hump, so I can use pickup carpet. I also converted to the factory green tinted windows from the clear windows it came with. I got deluxe locking vent windows from a 79 F-150, and converted the rear windows from front windows (changed tracks) I have a stock slider, but I kinda like the plain window since I cant reach the window from the drivers seat. I would like to see someone make the padded insets for the rear door panels, as well as the front (as well as the whole panels for the rear) I liked the inserts in my XLT crewcab with cloth seats, and want them for both my remaining crews. I eventually intend to get two camper special beds, and a regular long bed, and make a 12 foot bed using the spare tire doors to make a pass-through section in the first 4 ft behind the cab. and use 56-76 stepside fenders to make dually fenders, and several sets of F-600 steps, and longbed stepside steps to make factory looking running boards behind the step tanks. I thought about using a cab roof to make a sleeper type of filler over the 4 ft section, and then use a factory bed cap as well. I also would like dennis carpenter to make the crewcab specific rear door and center post trim, I had to make rear door strips from old bed strips, but I left one end open out of laziness.
__________________
1994 Bronco, 1996 Bronco, 1996 E-350, 1979 F-600 Crewcab, 1976 F-150 4x4 4-sp,1976 F-150 Crewcab,1976 F-250CS, 2003 Mercury Marauder and assorted other boring vehicles...
  #17 (permalink)
Old 02-12-2008, 11:39 PM
I would damn near trade my Marauder for that one, very nice, reasonable price too it seems
__________________
  #18 (permalink)
Old 02-13-2008, 01:03 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is starting off with a positive reputation.
Mine is a '76 F250 4X4 Crew. 360, 4-speed. In the middle of an integral power steering swap right now. Next will be a Powerstroke conversion. Oh yeah, and that rust thing you were talking about on the drip rails. Mine is relatively rust free except for that area and a very small area on the lower part of the cab in between the passenger doors. It clears 35's easily with 3-inch Rancho springs up front. Could easily run 36's.
__________________
Jhooch
'05 Excursion LTD 4X4 6.0, '01 F250 4X4 Crew 7.3
'73 Bronco 302 C4, '76 F250 4X4 Crew 360, 4-sp
'66 F100 4X2 LB Custom Cab 428, C6
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'63-64 Ford Galaxie's, 55 Ford Customline 2-dr
  #19 (permalink)
Old 02-13-2008, 04:40 PM
shoot4fun shoot4fun is offline
shoot4fun is starting off with a positive reputation.
Glad to see this thread going strong. I've got a place to post my pics... As soon as I can get started on the dang thing...!
__________________
Brad
'You can't fix stupid'
  #20 (permalink)
Old 02-13-2008, 07:52 PM
Pearl Pearl is offline
Pearl is starting off with a positive reputation.
First Post
Hi,
This is my first post to this thread, and obviously the first to the board. I just picked up a 77 F250 Crewcab. I've spent alot of time (according to the wife) reading all the various posts. My first question is how do you seal the drip rail to prevent rust? The previous owner had the truck painted about 5 years ago, is that good enough or should I try to seal the drip rail.
1977 F250 4X4
  #21 (permalink)
Old 02-13-2008, 09:56 PM
masterbeavis's Avatar
masterbeavis masterbeavis is offline
masterbeavis has a very good reputation on FTE. masterbeavis has a very good reputation on FTE. masterbeavis has a very good reputation on FTE.
Quote:
Originally Posted by Pearl
Hi,
1977 F250 4X4
That is an interesting question. I own two, both from out of state, (one from Utah) and both ran hard and put away wet. Neither truck shows any sign of rusting out at the drip rails after 29 years of abuse and salt roads(for the Utah truck.) The utah truck has a rusty frame, and a bad cab corner, but no rust in the drip rails. If you had access to a flexible shaft bore scope, and were willing to take out your headliner, you could take a peek on the inside to see whats going on. Welcome by the way.
__________________
Tony
Quando omni flunkus moritati - when all else fails, play dead.
If I posted something useful, click the http://images.ford-trucks.com/forums...reputation.gif in that post.
  #22 (permalink)
Old 02-13-2008, 10:18 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
That's weird. Almost EVERY crew I have EVER seen had rust in the roof line somewhere. Most have it about midway back on the cab just about the drip rails, and a lot have it in the front, upper corners above the windshield. The 77 I had was BAAAAAD, but it had those stupid cab marker, trucker type lights that lead to having 5-6 "skylights" in the front of the roof as well as the normal drip rail rust.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #23 (permalink)
Old 02-13-2008, 11:15 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is offline
78_f800crewcab4x4 is gaining momentum as a positive member of FTE. 78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
Hi,
1977 F250 4X4
to seal driprails: first get on a stool and look down into the channel (on the exterior). this is where the roof panel is spot welded to the drip rail; therefore, there is a seam. the factory used sealer in this spot but after 30 years, it is usually cracked and/or flaked off. if you dont see a crack or seam then you are good for now. mine was flaking off, so i used a wire brush attachment on an angle grinder to clean to bare metal (being careful not to damage the metal). then i degreased the area and ran a bead of seam sealer on the joint, smoothing the bead with a finger. it then needs to be painted. if the joint is a bit rusty, then that needs to be treated first with rust converter. paint wont seal seams.
__________________
1978 F600 Bronco 4 door "Centurion"
1958 F700 next "Centurion" project
1973 F350 Crew Cab Special, 460 all race
2002 Excursion Limited 4x4 7.3
Please help them:
http://www.lionconservation.org/index.html
  #24 (permalink)
Old 02-14-2008, 01:33 PM
johaner78 johaner78 is offline
johaner78 is starting off with a positive reputation.
78_f800 thanks for the insight on how to repair the seam sealer. However, my 78 crew's seam sealer was in excellent shape in the drip rail, no cracks, etc and mine was still rusted out mid way back (directly between the doors) on the roof panel that comes down to the drip rail. No way road salt was the issue, must be condensation then. Anyway, i ended up cutting out a section about 1" tall and 10" long of that roof panel and replaced with new metal.
__________________
1996 F150 4x4, 351, auto, LB, K&N Filtercharger, "Silver Bullet"
1978 F250 CC, sb, 4x4 "in the works"
  #25 (permalink)
Old 02-14-2008, 01:45 PM
1974 Ford F-250
johaner - your experience is the common one from what I've seen. My sealer still looks good, but I've got rust issues. I'm gonna do the cut and re-weld soon...
__________________
1970 Ford F250
  #26 (permalink)
Old 02-14-2008, 05:44 PM
be very careful with welding on the roof-very easy to break the surface tension, and warp the roof. (dont heat up the panel too much) not that you guys didnt already know.
has anyone mentioned how cool these trucks look?
i didnt mean to rust out this thread
__________________
Please help them:
  #27 (permalink)
Old 02-14-2008, 06:17 PM
1974 Ford F-250
when I weld I will be doing it with Silicone bronze rod and a TIG welder. Tack a ltitle bit, hit it with the blower on the air compressor to cool it off, then tack further down and repeat.
Tack welding rather than a continuous bead keeps heat out of the panel, as does the silicone bronze rod. Moving the tacks around also keeps heat buildup from taking place. The air hose trick is something new a buddy told me about that I haven't tried before but it makes sense.
The other benefit of the silicon bronze rod is it is easy to sand - keeping heat from building up in the panel ones again. Plus it doesn't rust!
If I wasn't cheap I'd get some silicon bronze wire for my MIG and put even less heat in the panel by MIG welding. I think my TIG method will suffice though.
__________________
1970 Ford F250
  #28 (permalink)
Old 02-15-2008, 08:47 PM
i finished modifying the electriclife power window kit to work in the rear doors. i dont have it all together working yet but i will post pics of the mods in my gallery soon.
__________________
Please help them:
  #29 (permalink)
Old 02-15-2008, 08:54 PM
i also purchased the polished billet 4 door A1 Electric switch kit to make it all work. also, has anyone used the window weatherstrip from jeffs bronco graveyard? does it fit good and allow the window to travel freely?
__________________
Please help them:
  #30 (permalink)
Old 02-16-2008, 06:47 PM
79f150toy's Avatar
79f150toy 79f150toy is offline
79f150toy is gaining momentum as a positive member of FTE.
hey, my bro just picked up a 74 cc f350 4x4....its a closed knuckle front, but is it a 60 or 70? or should I crawl under it and look(im at work now). how hard is it to swap disc brakes? can I swap off of a newer 50/60/70? also the bed is shot and the rest of the body is rough....but my brother has the intentions of transforming it into a centurion with the help of a 78-79 bronco....but that is just speculation..
__________________
***Matt***
"Beauty is in the eye of the beerholder."-Unkown
"What's today, but yesterday's tomorrow?"-Mr. Krabs
Tags
1970 , 1973 , 78 , 8 , 90s , bed , cab , crew , doors , f250 , f350 , ford , lowered , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
