johaner78 that is one sweet truck!! I hope that mine turns ot as nice as yours. Did your truck originally come with the racetrack trim, or did you add i afterwards. I plan on putting it on mine(i have most of the pieces) but my truck didn't have the trim from factory. anyways, good job!!
77crew, the truck came with the racetrack moulding and this is the original paint colors for this truck. Used the original PPG paint codes for the paint job. I really love this paint color combo! How lucky i was to find a crew with these colors. Truck was all black when I bought it.
I purchased all new racetrack moulding as it was cheaper than having all the old original stuff redone professionally. The only pieces I had redone were the pieces for the rear doors (top and bottom mouldings). Found a set of NOS lower mouldings between the doors and both the upper mouldings between the doors were on the truck (redone those as well).
That is awesome that you found the truck that way and used the oroiginal colors!!! I have almost all the reardoor racetrack stuff, except for one of the upper trim pieces. I've already been experiminting with cutting down a front door piece to make a copy of the rear. I filed a piece of aluminium to fit exatly in the end that i cut off and it looks ok so far. I also want the same color combo as yours, but i might go with a dark dark red instead of the black. Can you PM me the color code info anyway, it would be much appriciated. Thanks!
Has anyone else experimented with making their own rear door trim for the crews??? I'd be intersted in seen some pics if you have any, and i will try and post some pics of what i've tried too. Thanks!
