Warn Hub Install **Lots of Pics**
Hey Guys, this is the install of Warn 38826 Heavy Duty hubs on my 2000 6.8L X 4x4... To give you guys the background, I was out in a field in 2wd and the rear started slipping, so I put it into 4wd in the cab, but nothing happened at the hubs. I finally cracked off my hub covers and manually engaged them and got out fine, but it was a PITA. Instead of diagnosing the problem with the old hubs, (I wanted a new project anyway) I decided to order some warn Hubs. Here's the install:
This is where I had to crack off my hub covers - with an axe actually
Pull off the stock hubs by removing the steel ring as shown, then they just pull off. The driver's side hub was really stiff, and I had to beat it gently with a rubber mallet, and really wiggle it, but it came off eventually.
[img]http://photos-a.ak.facebook.com/photos-ak-sf2p/v182/226/27/607195429/n607195429_2332156_8912.jpg[img]
If you are curious, this is what it looks like inside wit the hubs removed- there's almost no grease in there by the way
I found this metal shaving in the hub space along with a bunch of other smaller ones
Here is a comparison of the 2 hubs:
Basically you just pop the inner part inside. I had to spin the outer splnes a bit to get the inner and outer ones to line up so the hub goes in
The hubs come with this little extra instruction to help you remove the retaining ring if you want to in the future...
Before:
AFTER
Then you feed the ring around
And it looks like this. Make sure its seated all the way around
Then put the o-ring on the hub and spin it around the inner part until it seats - make sure its UNLOCKED
Now torque the bolt they are 9/64 hex to i think its like 4.5 ft/lbs (I did 5 b/c it was the lowest my torque wrench would go)
To tie off the vacuum lines, I used vacuum caps
Here's the hose I No longer needed...
For the record, this is what you need to do inside the cab so the vacuum system doesn't drain when you activate 4wd
That pic's not mine, its from http://www.eurekaboy.com/f250/esof.htm . I recommend you read that link for more info too.
Here was the culprit as to why the hubs wouldn't work - the vacuum line had sheared off at the fitting so I didn't get any pressure >_<
Here are just some other things I noticed that you guys should check:
The front vent hose got broken by the driver's side bumpstop
My driver's side axleshaft seal slipped out (I have a feeling thats gonna be a big repair, what you think? Should I fix this NOW or is it ok to do it in a little while?
FINAL THOUGHTS:
The new warn hubs seem beefier, although the stockers actually freewheel better. It seems they have ball bearings and the Warn's only have bushings. The Warn's look way cooler though, but I dunno about the toughness factor between the two. Knowing what I know now, I might have just fixed the vacuum thing and saved $170 bucks (BTW, amazon is the cheapest place to get these things). Either way, they engage immediately, but in order to disengage, you have to go into reverse for a second to take the torque off the splines so the spring will push out the center part and they'll disengage. You can check for proper engagement/disengagement by spinning the CV joint in the knuckle of each side.
Hope that helps!
I'll answer any questions I can.
Thanks,
Before:
AFTER
FINAL THOUGHTS:
Hope that helps!
Thanks,
Originally Posted by njstevens
I would fix that seal now. Mine as well do the job comepletely.
on
I wouldn't cover those hubs up like that, a couple days ago I backed off a steep bank to turn around on a dirt road and backed up to a big rock but when I put it in 4WD with the switch it didn't go anywhere so I was out in the woods on a steep incline. The wheels need to turn a little bit for it to work but I knew the manual dials on my ESOF worked so I was out of there in a few minutes.
oooh... bad deal on having to bust in like that to turn your hub.
Good job on that write up though! Reps sent
One more vote to not worry about that dust seal for now. Its a long ways in there just to replace the dust seal. I would wait until you need to do ball joints or front axle u-joints to do that seal. Plus, there's another big seal (around $35 worth) that you'll likely trash along the way getting to that dust seal. And you will need to either make a seal driver or buy one (around $60) to get the new big seal on.
You can see some pics of this in my ball joint write up....
http://www.frontiernet.net/~jmray/F250BallJoints.htm
