Early 460 - Nylon timing gear?
Old 09-07-2000, 12:06 AM
Torky's Avatar
Torky
Torky is offline
I read something on a web site about a nylon sprocket being used on the cam end of the timing chain. And when the sprocket ages, it comes apart, nylon bits all over, including over oil pump pickup screen. But it wasn't clear if this was on the old 462, or the 460. Would a '69 460 have this nylon part?
Old 09-09-2000, 11:08 AM
Steve_Uzi's Avatar
Steve_Uzi
Steve_Uzi is offline
[font size="1" color="#FF0000"]LAST EDITED ON 09-Sep-00 AT 12:09 PM (EST)[/font][p]Yes it would, Factory engines use a Nylon timing chain gear on the cam because its not as noisy...
The gear is steel underneath and the teeth are nylon.. and when the gear goes.. your engine should start running like crap..
Cloyes makes a stock replacement steel gear set. or you can just get a double roller from any manufacturer for about $50.
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
Old 09-13-2000, 11:20 PM
Torky's Avatar
Torky
Torky is offline
Thanks, Uzi, that makes sense. The web site mentioned nylon teeth, and I just figured wrongly that the whole thing was nylon.
Old 09-22-2000, 07:22 AM
heavymetal's Avatar
heavymetal
heavymetal is offline
cadougherty_67
03-29-2017 04:04 PM
66v8baby
11-05-2016 06:36 AM
4x41977
03-02-2016 02:07 PM
Chevy Guy Gone FORD
General Automotive Discussion
09-02-2013 12:16 PM
jetrinka
17
12-19-2012 10:25 AM
Quick Reply: Early 460 - Nylon timing gear?
