Early 460 - Nylon timing gear?
I read something on a web site about a nylon sprocket being used on the cam end of the timing chain. And when the sprocket ages, it comes apart, nylon bits all over, including over oil pump pickup screen. But it wasn't clear if this was on the old 462, or the 460. Would a '69 460 have this nylon part?
[font size="1" color="#FF0000"]LAST EDITED ON 09-Sep-00 AT 12:09 PM (EST)[/font][p]Yes it would, Factory engines use a Nylon timing chain gear on the cam because its not as noisy...
The gear is steel underneath and the teeth are nylon.. and when the gear goes.. your engine should start running like crap..
Cloyes makes a stock replacement steel gear set. or you can just get a double roller from any manufacturer for about $50.
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
cadougherty_67
03-29-2017 04:04 PM
4x41977
03-02-2016 02:07 PM
Chevy Guy Gone FORD
General Automotive Discussion
09-02-2013 12:16 PM
