Help: Transfer Case almost fell out!!!
Just as the title says.. I almost lost my Transfer Case. The last couple days, I've noticed this front end vibration that is pretty voilent. I figured it was my drivers side ***** joints about ready to go as they are semi going bad. Well, to make a long story short, I planned on taking the truck up to the local shop Monday to get my ball joints replaced as its cold here and my truck won't come in a mile to fitting in my garage.
So, I drove down to get fuel and started thinking... I noticed everytime I would be on the gas even slightly, there would be NO vibration. However, as soon as I let off the gas in most cases, the truck would start shaking (mostly speeds under 50 mph). So a light went off in my head, check the drive shaft U joints. I got home, crowd under the truck and started shaking the drive shaft.... The whole drive shaft was moving up and down!! I looked around and immediately seen the entire Transfer Case moving back and forth!! It appears that I lost about 3-4 bolts towards the bottom of the case. There is about a 1/4 inch gap separating the bottom of the transfer case.. UNREAL!
I've noticed a leak at the bottom of the Transfer Case since I bought this truck about 6+ months ago. I did have a similar occurance about 3 months ago.. but it went away. Both times this seems to have happened when I used Drive 1 on the tranny going down a steep hill in my plan when it was snow covered. For some reason, when I use Drive 1 it makes this whining noise once I get to the bottom of the hill. Almost like the sound you get if you spin something the wrong way it should go. It only has done this twice and both times when I was coming down a hill. Would this have anything to do with it?
I'm going to run to the hardware store tomorrow to get some bolts and washers but could I have done any damage? Everything appears good still. However, the gasket for the Transfer case is torn at the bottom.
If anyone could give some input, I'd really appreciate it. It looks like the amount of room to get the new bolts in is going to be very difficult.
I'll post some pictures in a minute to show exactly where I'm talking.
I don't think the hardware store carries bolts of sufficient strength for what you need to do.
I would recommend going to some place that specializes in fasteners and get some 12 grade bolts and heavy duty washers.
Here in the Puget Sound area there is a place called Tacoma Screw.
Here's thier website. If they don't have it, I doubt anyone does.
http://www.tacomascrew.com/
Try a search for something like that in your area.
Don't use hardware store bolts, if you are lucky you will be able to get grade 8 and that is not very strong IMO for what you need to do. Most of thier stuff is grade 5, basically a stove bolt.
I was thinking grade 8 would just barely cut it but wasn't sure. Figures, I need the truck all week and unless I can pull off a miracle, I won't have it. I just wonder how long its been like this. It has to of been awhile atleast and maybe I just lost one or two more bolts recently causing the vibrations. It almost feels like I was running on a Rumble Strip.
Luckly, I found this now as I was getting ready to head up to the Mountains tomorrow. Imagine losing a drive shaft and Transfer case going 70mph...
What type of oil does the Transfer Case take? Has anyone taken one out before? Any suggestions?
It takes ATF fluid, about 2 qts, you might just stop by a dealer for the bolts, there is 6 all together, I'd replace all six and pick up some loctite if you don't have some already. Remember the transfer case housing is aluminum, so don't over torque them. You might even check them all out to make sure that is not the reason they dissapeared in the first place.
Originally Posted by Trailblazed
Will I have any issues with getting the new bolts in clearance wise? It looks like the bottom bolts maybe difficult to reach cause the crossmember for the frame is in the way.
I rebuilt my transfer case a short while ago after being towed home and I simply pulled the unit while the truck was parked in the front yard. Nothing special was required to get it out or back in. I forget now, what wrench size was needed, but I used these.
I wouldn't use the hardware grade bolts, if you are lucky they might be grade 5 bolts, most times they are grade 2. I would think you would want 5's or 8's in that spot. I would also use a little loctite when putting in the new bolts and look over your seals, you may want to replace the seals if it was run loose like that.
Is there a noticeable tear/rip in the gasket or is it a factory slit all the way through? IIRC when i replaced my tranny one of the gaskets for the transfer case or transmission or some shaft seal had a factory slit in it. i thought it was torn also, may want to check. Couldn't be that expensive to get a new one though, $5-$6? i would get the factory ford bolts if i could. Just my.02 though.
