as long as it is a 351m motor and not a 351 windsor motor. the 351m/400 shared the same bolt pattern as the 429/460 while the 351 winsdor is different.
thanks a bunch on that firing order and rotation. seems to have an extremely hot exhaust temp shortly after start up. i think timing is retarded too far may be running too rich too
I know this thread has been here a while but if you get it I have a question for ya.
I have a 1973 460 4bbl and I have the same problem, hot and seems like it burns rich. I was just wondering what you did to fix the problem thanks.
