why doesn't GVWR equal combined GAWR?
The front axle rating (GAWR) of the new 2008 F250 is 5250 lbs; the rear axle rating (GAWR) is 6200 lbs. If I add those together I get 11,450 lbs; but the max GVWR is 10,000. It's similar with my 1996 F250; front GAWR=3690 lbs, rear GAWR=6084 lbs, but total GVWR=8600 lbs. Why is that so?
my guess would be that that is the absolute max weight rating for the axles, and they want a bit of a safety buffer there. also, it provides enough room for different ratings. remember some places register by gvwr. so the different ratings let people choose the right rating for the applications they will use the truck for.
OK, GAWR is how much you can load the axle. Truck weight on the rear axle plus your load should not exceed the GAWR for the axle. Simple enough concept.
GVWR is total weight of the truck and contents. But....there is a hitch. If you load 6200 pounds on the rear axle, you can't load the 5250 on the front axle or you will exceed the GVWR. So, you can load up one of the axles to max GAWR, but not both axles.
Well, Redford, if GAWR really is the amount of weight you can put on an axle, and if the GAWR for the front axle is 5250 lbs, why then can I not put 5250 lbs on the front axle if I have 6200 lbs on the rear axle? I think Mark is on to something, but he hasn't said what exactly. Please help me understand this simple concept, instead of just musing on how simple it is.
The axle rating is just weight pressing down. The GVWR rating takes into account the ability of the truck to support AND move the load safely. The two ratings have nothing to do with each other.
You also need to consider the GCWR when factoring it all together. I've seen trucks that the GCWR isn't exceeded (truck + cargo + trailer weight), the GVWR is OK (truck plus cargo plus trailer tongue weight on entire truck) but the GAWR is exceeded (truck + cargo + trailer tongue weight on rear axle).
Originally Posted by redford
GAWR is static weight on the front or rear axle. GVWR is static weight on the entire truck. You can load the rear axle of the example truck to 6200 pounds, but if you did this and loaded the front axle to 5250 pounds you'd exceed the GVWR. Why?
Later...
Brewster...
What might that other "something" be, Mark?
Not only do all the other components (frame, springs, tires, brakes, performance, etc)figure into the equation, but if the GVWR was equal to the GAWR, then in order to load to max weight, you would have to get the load perfectly balanced between the front and rear axles - and that just ain't gonna happen.
