Keyless Entry Code
Old Feb 4, 2008 | 09:58 PM
DAB SUNNY's Avatar
DAB SUNNY
Keyless Entry Code
Hello-Trying to find the factory keyless entry code for my 2001 Ford Explorer Sport-Other threads have said its located on the computer module in the jack compartment on the 2001 explorer Sports.Mine is not.Others say its located in the dash .Does anyone know for sure-?Theres a guy on e bay thats sells the info for 15 bucks,but if he tells me to look in the jack compartment,I'm just throwing the $$ away,as its NOT in there.Help-Thanks-Dave
Old Feb 5, 2008 | 06:36 AM
lancer's Avatar
lancer
My 97 has a small card like a business card in the owners manual with the code on it. They have probably changed for your truck but its worth a shot.
Old Feb 5, 2008 | 02:01 PM
5.0B2's Avatar
5.0B2
Got mine for 97 Sport from the guy on eBay - he said it was on the module in the front end of the access panel just above and behind the left rear wheel. If that's where your jack is, they may have relocated it on newer models.
Old Feb 5, 2008 | 09:11 PM
winfordr's Avatar
winfordr
There is another thread here about a week or so old with detailed information. I believe it was found on the back side of the interior quarter panel, or side panel on the passenger side. Do a search in this forum for more info.
Old Feb 6, 2008 | 08:35 PM
4.0 Beast's Avatar
4.0 Beast
Are you sure its not there? it honestly should be, but its extremely hard to see. its a white sticker that has the numbers on it, very very hard to see. i had to strain for a few minutes to get 1 number at a time, but it was there.
Old Feb 8, 2008 | 11:36 AM
grilldemon's Avatar
grilldemon
keyless entry code
type in ford explorer keyless entry code on google. it will take you to wiki answers and explain where your code is found. On my 05 Eddie Bauer, the box is located behind the right rear passenger pillar. Right by the seatbelt mechanism. 01 is supposed to be where jack is stowed and article mentions you gotta put your eyeball on a stick to see it. All the instructions for setting up your keyless is also included. Here is the link
http://wiki.answers.com/Q/Keyless_En..._Ford_Explorer
Copy that in to your browser and you will have the same sheet I used
Good luck
Old Feb 8, 2008 | 02:03 PM
GeorgeRR's Avatar
GeorgeRR
If you haven't tried it yet, get hold of a dental mirror and tie it to a stick or something and look to see if there isn't a white sticker on the (I forgot the name of the module) side facing the inside of the trim panel slightly forward of the jack compartment. You will have to read it backward in the mirror, but not to hard. You will probably need a small flash lite also.They are pretty good size numbers. Another way would be to remove the entire trim panel on the driver side.
Old Feb 8, 2008 | 02:16 PM
DAB SUNNY's Avatar
DAB SUNNY
Guys-Hello-thanks,but my 2001 Ford Explorer Sport (2 DOOR)-does not have the computer module in the jack compartment.I have looked in there.It is NOT in the jack compartment.I think fors changed the locationnof the modual late in the production year-I think its behind the dash on the passenger side,but you have to remove part of the dash to look.I was at the dealer yesterday,to get a price on fixing broken door latcch(135+parts0 and asked the service guy to throw in the code,he wouldn't do it,but said he'd give me a "BREAK" and only charge me 1/2 hour labor($45) to get the code if I had the latch done.I walked out-!
askbruce
Mar 16, 2012 01:12 AM
tjtapley
Dec 10, 2005 06:32 AM
Excursion00
Mar 7, 2004 01:51 PM
Aug 25, 2002 10:40 PM
jkassab
Electrical Systems/Wiring
Nov 17, 2000 03:03 PM
