definitive test of penetrating oils
Old 02-03-2008, 06:39 AM
89Flivver's Avatar
89Flivver
89Flivver is offline
Smile definitive test of penetrating oils
got this from another forum, I am attempting to get the magazine and verify.
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
<st1:city w:st="on"><st1>Kano</st1> </st1:city>Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
Old 02-03-2008, 06:49 AM
JLDickmon's Avatar
JLDickmon
JLDickmon is offline
if you can verify it, great.
you can't believe how much PBlaster we go through in a month...
Old 02-03-2008, 07:01 AM
89Flivver's Avatar
89Flivver
Talking
For myself, I am a Kroil fan. I have be defending Kroil vs PBlaster for over 2 decades, though not vigorously!
Old 02-03-2008, 07:52 AM
subford's Avatar
subford
subford is offline
I heard how great PB Blaster is so I bough it and tried it but it never seem to help at all.
So I then started using WD-40 on one side of the trucks and PB Blaster on the other.
The WD-40 treated ones came loose and PB Blaster ones broke or had to put WD-40 on them to get them off.
I have gave up on PB Blaster will not buy it any more but I did give it all kinds of chances to work.
Old 02-03-2008, 08:17 AM
netscaner's Avatar
netscaner
netscaner is offline
It depends on the type of rust and the conditions and situations and the age of the corrosion.
I have found that using Blaster, then heat when possible, then Blaster again to break it loose (Blaster contains an acid which disolves rust), then WD, Free-All, or similar smooth lubricant to help it slip and not bind on rusty residue as you finish removing it works best for me.
Old 02-03-2008, 08:35 AM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
what is the best to loose manifold bolts? or like o2 sensor?
Old 02-03-2008, 09:27 AM
flareside_thunder's Avatar
flareside_thunder
flareside_thunder is offline
The correct size wrench...I'm gonna have to try that atf acetone thing....
JR
Old 02-03-2008, 10:13 AM
ottawaguy's Avatar
ottawaguy
ottawaguy is offline
Well I've never tried the atf thing...which I will try.
Here's another little known secret.
Candle wax.
I only recently read this on an offroading site.
It said to heat the bolt quickly and apply wax to the threads...which gets sucked into the bolt. Reheat and reapply wax a few times(which only takes a couple of minutes).
It apparently cleans the threads as well as lubricating them.
I just tried to find that thread but couldn't find that one, though google did find other pages on the subject. It has also been discussed on this site before.
Anyway....thought I would put this up. I haven't tried this yet since it's still winter here and not really doing anything to the truck till spring. I will try it as soon as get the chance.
Old 02-03-2008, 10:36 AM
subford's Avatar
subford
subford is offline
I tried the wax and never had any luck with it.
I will try the ATF thing next time.
Old 02-03-2008, 11:59 AM
quicklook2's Avatar
quicklook2
quicklook2 is offline
this is the most interesting and helpful thread in a long time.
i will also try the atf/acetone mix next time.
Old 02-03-2008, 12:40 PM
jr32560's Avatar
jr32560
jr32560 is offline
this is some good info-only problem I see with the atf-acetone mix is I would be afraid to use heat-open flame
Old 02-03-2008, 12:59 PM
NeXtras's Avatar
NeXtras
NeXtras is offline
in teresting..
i think its funnyhow dumb they think people are "50/50 mix (1 to 1 ratio)" jee ya think!
Old 02-03-2008, 01:29 PM
capn kirk's Avatar
capn kirk
capn kirk is offline
Originally Posted by NeXtras
in teresting..
...you should meet some of the people out there they probably considered writing "half ATF and half acetone" after that
Old 02-03-2008, 01:33 PM
jr32560's Avatar
jr32560
jr32560 is offline
well in there defense-there are some dumb people in this world!!! better to spell it out!!!
Old 02-03-2008, 01:38 PM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
very glad i found Aero-Kroil, some amazing stuff that i save for the hard-to-remove stuff...like my upcoming manifold/header job
Quick Reply: definitive test of penetrating oils
