1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 VS F150 Bed size
Old 01-27-2008, 11:05 PM
horseman54's Avatar
horseman54
horseman54 is offline
Is there a difference in size of a full size bed between a F150 and a F250? I tried to install a tonneau cover for a F150 on a F250 and it was a couple inches short. You could put your hand between the rear of the cover and the tailgate top. My F250 is a 1999 model and the tonneau is a 97 - 03 F150 model. Also the width seemed to be a little wider on my F250. When the clamps were tightened down on the rails the bows did not fit snug.
Old 01-28-2008, 07:24 AM
one_wicked_element's Avatar
one_wicked_element
one_wicked_element is offline
Yes, I noticed a difference as well. I had a 98 F-150 that I would keep sandbags in for winter. I had some wood dividers to keep them in place. I tried to put the wood in my truck and it was too short.
The SD bed is bigger then then F-150's.
Old 01-28-2008, 08:17 AM
RogueSpear2023's Avatar
RogueSpear2023
RogueSpear2023 is offline
If its a short bed the F-150 is a 6 1/2' bed the F-250 is a 6 3/4' bed. Long beds I think are the same 8' for both. Also a F-150 supercrew has 5 1/2' bed and a crew cab F-250 has a 6 3/4' bed. I don't know about the width, but I would assume the are a little wider, I don't have the specs at hand though.
joeskeeter
03-17-2014 08:49 AM
MFW
03-12-2014 01:08 PM
xc4jokestomper
17
06-16-2010 10:33 AM
F100 Cobra
04-09-2007 07:06 PM
Quick Reply: F250 VS F150 Bed size
