1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Pulling a goose neck trailer
Old 01-28-2008, 12:20 AM
drmitch's Avatar
drmitch
drmitch is offline
Has any one lifted there trucks that pull a goose neck trailer. I wanted to do a 6 inch lift and wanted to know if it will work. And what size tire can I run on a dulley. Thanks
Old 01-28-2008, 12:25 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
If you get a 4" lift that uses rear blocks you won't reduce your loading ability. To get a soft enough ride with a 6" lift you'll need really soft springs and airbags to tow anything.
Old 01-28-2008, 06:32 AM
HorseyHauler's Avatar
HorseyHauler
HorseyHauler is offline
Watch the clearance between the bottom of the GN and the truck bed sides when lifting the truck. You'll change the angle and could be a problem unless your trailer is really tall.
Also, could make the rig combination unstable and definitely reduce your mpg.
Search for posts on tires, dually to get some good feedback. Believe the dually design limits the size of the tires because they are side-by-side.
Old 01-28-2008, 07:52 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Welcome to FTE.
I have run 265 75R 16s for around 100,000 miles. I keep the tires at 80 psi and never had any problems. That is about as big as you can go.
Good luck.
Unk Jim
11-21-2014 01:43 PM
GaRcIa94
07-08-2014 10:52 AM
DanielT28
11-12-2012 12:08 AM
DanielT28
1997 - 2003 F150
10-05-2012 02:06 AM
79fordf250pickup
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-18-2011 09:18 AM
Quick Reply: Pulling a goose neck trailer
