bleeding clutch
Use a mity vac vacuum pump to bleed it make sure you have someone dumping in
fresh fluid because it sucks it out fast!! It is a great thing for bleeding brakes I
pull the fluid out of the master cylinder first and refill it that way I have fresh fluid
throughout instead of a crappy mix of old and new fluid. It has a lot of uses and
can save you from swapping vac controlled components by testing them instead!!
http://www.mityvac.com/ read the tech info on clutch bleeding!! If you get one
buy the one with the gauge so you have an idea what your pulling and for testing
motor vacuum.
motor vacuum.
If this is the concentric slave (Slave in bell housing) i had the same problem. I finaly got a tapered fitting that would fit tight in the bleeder fitting and attatched a hose to it and slid it in the bleed hole. Filled a cup up with fluid and the master up with fluid and stuck the hose in the cup. Then had someone pump the peddle. The way this works as the peddle pushes out the air it will also suck fluid out of the cup and into the clutch system. Once you have pressure you can bleed it like brakes.
ItsAFord55
12-27-2015 07:11 PM
cinbearcat
Escape & Escape Hybrid
11-30-2013 05:52 PM
srumble
11-17-2007 06:36 PM
